I bought a set of these a long way back.
SlickRock Fabrication Disco2 ABS Extension Kit (ABS)
They were considerably cheaper back then.
Also I only used the rears and on-sold the other 2 to recoup a lot of my outlay.
Yo, what’s every one doing for ABS extensions? what cable are you splicing with or does someone make extenders ?
I have fitted my HEL +4" brake lines and I was out in the paddocks today testing it with the sway bars removed, fronts look good both ABS and brake lines, plenty of slack.
Rear, little disappointed I was expecting to be at least 1" more in the brake lines, don’t really seem fit for a big lift. But the biggest issue is the ABS cable, lucky I stopped where I did as it was tight.
Happy Days
_________________________
1996 D1 V8 - gone
2002 D2 Td5 ES- gone but still running elsewhere
2013 D4 SDV6 HSE - gone
2023 Defender 110SE D300
I run 3inch suspension with hel 4 inch brake lines and my abs are fine and have removed the sway bars
03 D2a Manual Td5 Modified, Ashcroft lockers F&R, Ashcroft R380,Atb lt230, Ashcroft Rear axles, AS manual IC, AS exhuast manifold, AS Coolant bottle, 3inch exhaust, alive GTB550 VGT, billies 7100s, 3inch lift, 4inch staino snorkel, 35s beadlocked
So, I took a gamble on these from eBay that came up as WABCO truck ABS extension cables. I recall a video on YouTube from Trailerfitter's Toolbox, who does many disco videos where he said the abs cables were the same as trucks he works on.
They look about right from memory. I will try to fit them tomorrow.![]()
FITS RENAULT MIDLINER EXTENSION LEAD TRUCK/ HGV/ LORRY 1912312 | eBay
