Not 100% sure but a relatively quick, simple & cheap thing to try would be replacing the ignition switch (the one at the end of the key barrel). Known to fail & cause odd starting results.
Then try checking/reseating the ignition/starter relays - I think they are the ones under the seat.
If no joy it may be the dreaded immobilizer issues... Which I understand are very difficult to resolve (sorry, I realise I'm not helping with that statement...)
Hope you get a result, good luck!
