Results 1 to 10 of 11
Thread: Rear door demisterno good.
    May 2015
    Williamstown, Victoria
    Not that it does get a lot of use, BUT! it did work. Now three of the lines work. Is there a way to fix this?
    Julian
    Build date 11th Oct 2003
    LROCV #1410
    Apr 2015
    Hervey Bay
    You can get a demister repair kit if you can see where the lines are broken. Just hope you don't have tint.
    https://www.repco.com.au/en/safety-w...117/p/A5320200
    04 L322 Vogue V8 - Work truck
    07 Freelander 2 TD4 SE - The wifes
    74 Leyland P76 Targa Florio - Aspen Green
    91 Kawasaki GPZ900R
    Previous LRs = 78IIa series - 81, 93, 95 RRC - D2V8
    May 2015
    Quote Originally Posted by FisherX;[URL="tel:3100001"
    3100001[/URL]]You can get a demister repair kit if you can see where the lines are broken. Just hope you don't have tint.
    Excellent, thanks for this. I do not have tint.
    LROCV #1410
    Jan 2011
    Gippsland
    Quote Originally Posted by Bohica View Post
    I have used the LOCTITE liquid on other vehicles - it worked successfullyRear door demisterno good.
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    May 2015
    As always YouTube can help. Except I have many breaks and the repair looks ugly.
    https://www.youtube.com/watch?v=QKTB5QThWIc
    LROCV #1410
    Jul 2014
    west of Transylvania
    You can replace the whole thing too with kits like this Clear View Aftermarket Defrosters and Defoggers
    May 2015
    The clear view kit is only $100 less than a new window including postage. Then there is the skill of the operator to consider!
    LROCV #1410
    Jul 2014
    It was for example, there are similar kits cheaper if you search
    May 2015
    Quote Originally Posted by sierrafery View Post
    There is still the skill level to consider!
    LROCV #1410
    Back down the hill.
    Or lack thereof.
