Results 1 to 10 of 22
Thread: power Quizz What is my Power bug bear
    Feb 2010
    Some items we have at home or work when they turn on go to work quickly and crank up the watts on the power circuits. I have had a few years of wondering exactly what was a huge power hog at work. Power off then on and the spike was often 10,000w plus. Just occasionally that bit me.
    The suspects:
    1. Hot water system
    2. Fridges- 4 of them. Two big vaccine fridges and two smaller bar fridges
    3. Elevator
    4. Computers 9 of them
    5. printers 7
    6. Lights- almost all LED
    7. 2 5000 w Victron inverter chargers
    8. Two 10kwh Redflow batteries
    9. A phone charge or similar - 6 or so
    10. Solar PV input upto 5.2kw
    11. Kettle, Microwave, toasted sandwich maker
    12. Air conditioning Splits systems. Multiple Mulitiheads and five single units up to 3.5kw heating/cooling ( Thanks Ian) Hint- they got turned off first and are not the answer
    Hint -My two batteries and two 5Kwh Victron multi plus can cover peak loads above 10,000 watts for a short time when every thing is smiling. They batteries can suck in 5000 watts when charging. Power spike only occurs for several seconds when item or circuit is first turned on.
    A 4 hours item by item testing last night finally solved it for me. Sparky and I both lost .
    Rulz pick ONE Number 1 to 11 or type one answer for my power spike hog. First Correct post wins! Multiple guesses disqualified No questions sorry unless no correct answers in a week from now
    May 2006
    Woolgoolga
    Why are your batteries charging from the grid, or do they charge to a particular soc then pv tops them up?
    How are you monitoring all loads?
    The kettle
    Back down the hill.
    Don't you have air con?
    Nov 2015
    Black Rock
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Feb 2010
    3
    Editing Thanks
    Feb 2010
    3
    Edit- Lift spikes to < 2000 w only
    Feb 2010
    Quote Originally Posted by DieselLSE View Post
    1.
    They can spike to sub 4000w if we turn them on and being used- Sub 3000 w if all active. Almost no spike if power just turned on to the circuit.
    Aug 2010
    Sunbury, VIC
    7 - Only based on peaks I used to see when working in Exchanges testing gensets. When first powered on the rectifiers would suck huge loads just for a short time after powering up. Complete guess though.
    Feb 2010
    Quote Originally Posted by Homestar View Post
    Victrons pull or push whats is drawn tiny efficiency loss from AC/DC - DC/AC. they can take peak surges over 14,000 w for a short time but are not my problem in this instance or questions.
    Victron units perform ‘loss of mains’ (“LOM”) detection and can in some instance blow back apparently
    Not the issue for the quizz but very interesting in LOM as a possible other danger to my UPS set up.
