Results 1 to 6 of 6
Thread: maximum size 18" tyres on L322
    Mar 2011
    Balbarrup WA
    Looking for a slightly higher profile tyre to put on an 08 L322.
    I have 18" rims.
    Was looking at 255/65 18, but stock not available at present.
    Does anybody know if I can fit 265/65 18" without scrubbing?
    NSW SW Slopes
    265/65R18 are nominally slightly smaller in diameter than the 275/55R20 that I have fitted and will be slightly narrower. The 275/55R20 clear when on the bump-stops (found out recently) but rub the liners if the steering is turned much and rub at access height if the steering is turned a lot. I'm planning to fit 255/60R19 as my next tyres which are 31" and narrower to ensure that the vehicle can be driven on the bump-stops if necessary.
    Aug 2013
    Howrah, Tas
    Quote Originally Posted by vbrab View Post
    I have 18" rims.
    Hi,
    I've being using 265/60 18 and works perfectly for me, even doing 4wdriving.
    Jason
    Jason
    Range rover l322 2002 TD6
    Dec 2010
    Mirboo North Victoria
    If it helps i am running 265/60/18 Wildpeaks on my L322 with no issues and have installed 265/65/17 on our Discovery 3 last week i am very impressed with the Wildpeaks they are very quiet and still very tractable off road given they are the A/T version and the Discovery ones are L/t rated my wife is very impressed. She travels over some gravel/sandy roads on her daily drive to work and stated the difference was amazing compared to the Bridgestone Duelers she had previously.
    Regards Gippy
    Mar 2011
    Balbarrup WA
    Re Trying to fit 265/65/18 to L322
    Quote Originally Posted by landie56 View Post
    Hi,
    Jason
    Main reason I am looking for higher profile is that I seem to be dead unlucky cutting sidewalls, even when running on bitumen, and hoping a slightly higher sidewall might reduce such events (as didn't seem to get them on other Land Rovers running 65 and 70 profile tyres.
    Looks like I may have to settle for 60 profile.
    Mar 2011
    Balbarrup WA
    Re larger profile tyres on L322
    Quote Originally Posted by Gippslander View Post
    Regards Gippy
    Yes, found I could mount 265/65/18 on my D3 but couldn't fit the spare underneath (had a rear carrier), but the L322 doesn't seem to have the wheel arch space (not sure about spare wheel space either), and I have been warned that should suspension drop Tyres likely to rub.
    Looks like 265/60/18 are where it will have to be.
