Results 1 to 10 of 13
Thread: New MY22 D5 D300 on order. Wheels, tyres and AC questions ...
    Adelaide
    Hi all,
    Having enjoyed our MY11 D4 for many years, we have decided to upgrade and placed an order for a new D300 HSE earlier this week. Excited, but am told a 10 month wait
    Anyway, I am rethinking some of the options after perusing AULRO! Only ordered this week, so should be able to change if needed.
    Current order is for Fuij White HSE D300 with:
    • Active rear diff
    • Twin-speed transfer box
    • Front opening sunroof
    • Black roof rails
    • Tow hitch
    • Tyre pressure monitoring
    • 22inch S5124 Gloss Black wheels
    I have read with interest comments regarding the 3 zone climate system here. We decided to just go with the standard air conditioning, but am now rethinking optioning the 4 zone given the comments on this site. Do others find the standard system is sufficient in Australia with kids (and dog), or should we go for the 4 zone?
    We also deliberated long and hard on the wheels. We do some trips and offroading, but realistically spend 95% of our time on roads. Ultimately decided to go with the 22's and will probably pick up a second set of 20's or 18's when we need them. This might seem an odd choice given we are putting the active rear diff and dual range in the car, but the HSE comes standard with 21's, for which there seems to be very few (if any) AT options, and it seemed a little silly to go with the 20's given we spend most of our time on the tarmac. Ironically, there also seems to be at least a couple of AT choices in 22", where I can't find any in 21". I am aware that these don't really offer any sidewall to speak of, but I see Nitto do a 285/45R22 Terra Grabber G2, although not sure if it will scrub as it adds 28mm (3.6%). Would be interested in your collective thoughts on this as a plan. Am I missing anything? Have any tried this tyre for fit?
    Thanks!
    Oct 2016
    Perth, AU
    Holy **** - 10 months?! You'd almost be up for the MY23 by the time you get it wouldn't you?
    Does your D4 have rear air? This might help decide if you need it in the D5?
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Heathcote Junction
    I put bigger tyres on my 20" rims and the ride improved noticeably.
    I am running 275 55 20 Nitto Ridge Grapplers so clearance on the 22's wont be a problem although ride quality wont be as good.
    Chuck
    MY 24 Grenadier Trialmaster
    MY 03 D2a
    Ex D1, D2, D2a, D3, D4, Prado, D4, D5, MY 23 Defender
    73 series 3 109 Truck Cab Tray Body, 79 Series, 76 Series
    Adelaide
    Quote Originally Posted by veebs View Post
    Crazy right! The dealer did say that 10 months is worst case scenario, so could be sooner. I think they are setting expectations
    We didn't option extra air in the D4, but it is the HSE, which certainly has additional controls in the 2nd row. It also has a 2nd on/off for aux air on the front console, so I think that the HSE at the time must have had a 2nd compressor as standard.
    Adelaide
    Quote Originally Posted by chuck View Post
    Thanks. That is good to know.
    According to Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com, the 285/45R22 are only 4mm larger that the Nitto's that you are using, so should be close.
    Oct 2011
    Hunter Valley
    I have a 5 seater with standard aircon. If I were to get another one I would consider getting the solar attenuating windscreen, due to the more raked and much larger windscreen compared to the D4 it gets hot very quickly inside. But the 3 retrievers in the boot never complained about it being too hot. On hot days, I remote start mine to cool the interior down for a few minutes before getting in.
    Ron
    2016 D4 TDV6 Corris Grey
    2018 D5 TD6 SE Silicon Silver - gone
    2011 D4 TDV6 2.7 Indus Silver - gone
    IIDTool BT
    Adelaide
    Quote Originally Posted by IndusD4 View Post
    Ron
    Thanks Ron. Interesting point regarding the windscreen. So many options! I've decided to just bite the bullet and get the 4-zone AC. For the sake of a bit extra, I don't really want to run the risk of the car being hot all the time. I'm not going with the solar attenuated windscreen, because we tend to park undercover most of the time.
    My two bob's worth...
    I have a 19MY with 20" rims. You will find the ride better on smaller rims and the range of AT tyres is also pretty good - especially compared to 22" rims. I drove straight from the dealer to a tyre fitter and swapped the original road tyres for Nitto Terra Grapplers in 275/55R20. They are as quiet as the original tyres and are a good AT tyre - not for rock hopping, stick with the Ridge Grapplers for that, but you cop a big weight gain.
    Like most people, I spend most of my time on bitumen so I did not want a really heavy tyre - the extra unsprung weight was a worry. I run the tyres at 32 psi front, 34 psi rear around town and slightly higher loaded up on bitumen. I can drop them as far as 16 psi if I have to.
    Numb Thumbs
    Fuji White 2019 SE Sd6
    I've got the solar windscreen and while it certainly blocks the heat............I've had more stone chips in 3 years (and one new windscreen as a result) than in my whole driving life. Could be a coincidence of course.
    At 3k replacement cost its worth ticking that option on your car insurance.
    Ron
    Adelaide
    Yes. I did think about the solar windscreen as well, but the options list was already growing too long for my liking and I had the draw the line somewhere... and as I mention above, unless we are travelling the car is garaged most of the time. Time will tell whether I regret this choice!
