Results 1 to 10 of 12
Thread: Abs pump.
    Dec 2017
    Mornington Vic
    Abs pump.
    Next on my list (a long, long list) to fix on Rosie is the brakes.
    After a great deal of reading about the abs pump I think I'd like to try just replacing the accumulator rather than the whole unit.
    I have brakes but they take a few seconds to come good on first start if day. I get a flash of abd/tc lights but no errors come up in message screen.
    What does the brain trust think? Or should I dig deep and replace the lot.
    Mjs
    Nov 2015
    Black Rock
    Replace the accumulator. The ABS pump is easy to overhaul and will probably only need a clean. Make sure you completely flush the WABCO unit, too. They don't like old fluid gumming them up. Before you start, buy this book Range Rover ABS brakes explained, '90 to '02. Book. Download. Range Rover ABS brake system information book (jewellamberoil.com)
    2013 D4 expedition equipped
    1966 Army workshop trailer
    Oct 2007
    Williamstown, Victoria
    +1 on replacing the accumulator.
    I had the exact same symptoms and a new accumulator did the trick.
    Easy job, just depressirise the brakes first as described in the rave manual.
    I did mine 8 years ago and not had a problem since.
    Oct 2011
    Fremantle WA
    Quote Originally Posted by DieselLSE View Post
    Good luck finding an accumulator - I ordered 2 new ones ex overseas one after the other with both getting refused air transport.
    Eventually got a used one from TRS in Adelaide - but not sure if it was in any better condition than mine, but swapped over anyway.
    ABS pump replacement was refurbished ex USA, then found out Falconworks will rebuild.
    Sep 2020
    Gold Coast Australia
    ABS pump issues
    Quote Originally Posted by Saulman1010 View Post
    Mjs
    Dont rush to "replace the lot" unless you have a bundle under your mattress. As suggested replace the accumulator as first step. My old 1998 P38 had issues as well. Relay failed, replaced with brand new RR unit, $125 Oooh, found out this model needs a thin pin on the ABS relay. trimming down the pin on a standard relay worked but pump still ran continuously, fitted new accumulator,bought from local supplier, pump still still ran on. Brakes worked ok but waited for motor to burn out as I tried everything to fix this, bleeding etc. Even over several weeks this didn't happen despite so many messages suggesting a few minutes would burn it out? Replaced pressure switch, no change. Began to suspect the pump wasn't putting out enough pressure. Looked at buying a local refurbished pump for around $1000 but found a brand new unit on Island4x4 for UK 875 pounds..around $1,500 Aud. way to go I thought. big mistake, hit with GST and other govt clearance taxes plus freight, ended up around $2500 Aud. Came with accumulator and pressure switch, genuine German made unit, Wabco. Well, it fixed the problem with the ABS but not the bank! By the way, if anyone's looking for an unused new accumulator or genuine relay I have one of each to sell.
    Dec 2017
    Mornington Vic
    I've ordered an accumulator 4 weeks ago from someone 25min drive away. Not real happy with AU post atm.
    I'm getting errors every trip now. Going to be off the road soon!
    Dec 2017
    Mornington Vic
    Finally got the accumulator. Webco right part No, now I have to pluck up courage to try fitting it!
    Mjs
    Jan 2016
    Netherlands
    It's not so bad mate I have done it many times now. They run with quite a few threads screwed in so take a big rage to put around the coupling to catch the oil, loosen it and slowly turn. It'll squirt out and that's it Leave the car overnight and it'll be even easier.
    Good luck!
    -P
    Dec 2017
    Mornington Vic
    Done the accumulator, just now can't reset abs sensor error. Going to have to pull the wheel off and reseat sensor.
    One step forward...one step back.
    Mjs
    Dec 2017
    Mornington Vic
    Ok. Brakes much firmer. Not weeping. Very happy.
    Had a look at the LH abs sensor and it looks pretty bashed about....I had the ball joints replaced a few months ago and I suppose they copped a bit of abuse then.
    Have ordered two new ones.
    Sighs heavily
