Results 1 to 4 of 4
Thread: Only Normal Height ?
    Mar 2012
    Cooroy
    Any ideas why Only Normal height available comes up irregularly. If not showing the the car raises and lowers with the button with no problem!
    2010 D4 3 lt
    Thank you
    Mar 2016
    You have a suspension error that you need get the codes read for. Most likely a bad compressor and will need a rebuild/replacement, but without the error codes were playing pin the tail on the donkey
    2007 Audi RS4 (B7)
    NSW SW Slopes
    Depending on the particular fault, it's likely to increase in frequency and may lead to dropping to the bump-stops if the cause isn't fixed.
    Sep 2011
    Central Tasmania (formerly Adelaide Hills)
    Yes, “bump stops”. They are the most inappropriately named item. If you ever have to drive a D4 on its bump stops you will discover that the one thing they don’t do is stop bumps.
