Results 1 to 9 of 9
Thread: Low Pressure Fuel Pump replacement - 2006 Discovery 3
    Sep 2021
    Toowoomba
    Hey guys,
    I am new here and relatively new to Land Rover ownership. I have recently purchased a Discovery 3 (2006 model, 2.7l TDv6). I have run into issue after issue since buying mostly due to not doing my homework and buying a bit of a lemon. I absolutely love the car though.
    My mechanic has said I need to replace the low pressure fuel pump, but has quoted me in excess of $1600 to replace it. I wouldn't mind doing the work myself as I am quite handy when following a guide but I don't know where to start as far as parts purchasing goes or what tools I might need for the job. I have found several listed on EBay for around $225, which seems a lot easier on the wallet than $1600.
    If anyone else has done anything like this before I would love to hear how you did it and what you needed to get it done. Conversely, if I should just bite the bullet and pay to have it replaced professionally feel free to let me know that as well.
    To gain access you need to drop the fuel tank.
    Sep 2021
    Toowoomba
    Thanks mate, I'm aware of that. Have you ever dropped the fuel tank? I know the basics of it, just not sure if I should get any specific tools/read any specific guides before climbing underneath and getting stuck in.
    BradC is online now Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    There are a number of good threads on the UK Disco3 forum. The general consensus seems to be it's a bit of a pig of a job, but doable at home. On that basis, use a genuine LR pump assembly as the aftermarket ones don't have a great reputation and it's not a job you want to voluntarily do twice.
    Jul 2021
    Hatton Vale qld
    Fuel pump
    I am afraid to say that most jobs on the tdv6 is or are a pig of a job. I have a 2005 disco 3 no end of problems. Injectors, leaking rocker cover gaskets, knackered oil cooler, cracked dash, plastic mouldings missing clips and sun baked. Door straps busted. But as someone said looks nice sitting on the side of the road waiting for the two truck again. U need a good bank account to keep it running. If I had a gun I would shoot it.
    Jun 2013
    Universe A
    No special tools are needed really as far as hand tools.
    But I did use the hoist and gearbox Jack.
    If I was doing it again:
    Pull the LPFP relay, bridge it and pump all the fuel out of the tank via the Schrader valve.
    Depending on what year the car is it will have 1 of 2 different fuel filter styles, the hoses running back to the tank Will need disconnecting there. The tank guard is what actually holds the tank in, it is not bolted separately.
    It's pretty awkward with only one person working on it, I really don't know how you would do it without a hoist, or at the very least a pit.
    Most of the fittings that need removing from the top of the tank can be removed without too much bother, but get it as clean as possible with compressed air before starting.
    The are 3 multiplugs (that cannot be inserted improperly due to design) that need unplugging and at least one other pipe fitting in tank.
    Getting the pump in and out of the tank is a nightmare IMO, there is a retaining band that the needs unclipping but it's nearly impossible without getting the pump out first.
    From memory all the pipes that run forward need pulling up through the hole before the pump, that will "simply" follow the pipes.
    Disassembling the pump is pretty easy of your are only going to remove the pump module itself, but you may need a heat gun for one of the pipes.
    Re inserting the pump in the tank is akin to reverse childbirth, the worst 2 bits are getting the fuel gauge arm back over the obstructions and between the mount and tank wall, without bending it, which I managed, and of course refitting the retaining strap.
    All the best..
    I would do my own again if I had too though.
    Belated question... What's it doing that requires a replacement?
    May 2012
    Tingha NSW
    YouTube help for D3 and D4
    Quote Originally Posted by BSTACK View Post
    Hey guys,
    You might like to have a look at LR Drive on YouTube. Land Rover Drive - YouTube
    Also LR Time for lots of good German engineering saving $1000s of hard earned.
    LR TIME - YouTube
    Sep 2021
    Toowoomba
    Quote Originally Posted by shack View Post
    Hey mate,
    It doesn't start when cold/sitting for a while. It'll turn over right away and conk out 2-3 seconds later. It will start again after cranking for 5-10 seconds and run rough for a little while before sorting itself out. Mechanic said the fuel pressure was low and that indicated it might be the LPFP. Changed the fuel filter and a few other things myself just to make sure that was it and all signs seem to be pointing to that.
    Every now and then it'll run rough as well and I need to bleed the fuel line and then it's right as rain again.
    Jun 2013
    Universe A
    That's a bummer, hopefully you can find a quality replacement.
