Results 1 to 9 of 9
Thread: D4 TDV6 Deisel
    grhumphr Guest
    D4 TDV6 Deisel
    Morning all 5 year looker,1st post
    My question is in no way blaming nor shaming.
    We have had our D4 07/2014 since Aug 2017.
    Has any one had this issue whereby the speed of veh is 4kmh slower than actual speed.
    This has been shown by my heads up unit and the many digital speed units at roadwork sites around our state.
    Veh is always fitted with BLR recommended size,rated tyres.
    What if, anything has been done to rectify other than re changing tyre specs.
    Regards G
    Apr 2012
    Whyalla, SA
    This is normal to pretty much every vehicle produced.
    It’s due to laws and tolerances.
    You can correct using a Gap IID tool
    St Helena,Melbourne
    1.13 MB
    Completely normal with almost every vehicle sold in Oz, they are normally 5-6 kph out.
    I would leave it as is and make allowance with your speed.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2020
    all five cars and two motorbikes I've owned have been the same. about 5% out (5km/h out @ 100km/h). It's completely normal.
    You can fix it by fitting 265/65 R18s!
    Gladstone
    That's interesting I am going to look that up.
    Oct 2011
    Fremantle WA
    Quote Originally Posted by mowog View Post
    I fixed mine by changing the tyre size to the next up (5% taller) via GAP Tool
    Mar 2016
    Adelaide
    Mine was 5-6% out. I put on 285 60 18 tires which are 5% bigger than standard. Fixed the speedo but my odometer is now 5% under. But I can fix that when I buy an iid
    "Land Rover - making mechanics out of everyday motorists for nearly 70 years"
    Dec 2014
    Townsville
    Same same - I just set the cruise control by my GPS!
    Narangga's Avatar
    Jun 2008
    McMinns Lagoon NT
    Seems it might be: Speedo vs GPS
    Cheers, Dale
    'The D3' - 2006 TDV6 HSE
    Previously Enjoyed:
    2000 D2 Td5 - plus!
