Results 1 to 10 of 11
Thread: Low Coolant Alarm and Engine Cut Out
    Sep 2018
    Travancore
    After a day doing the wiring for the D2 and finding an output from the low coolant alarm which can be used for tooting the horn, a sounder etc. Just had the thought which in some ways seems reasonable, using this to connect to the fuel cut off switch (having used the fuel cut out switch 'bracket' to mount the catch can).
    Have the LED outlet to mount in my pod on top of the dashboard where it should give a pretty early indication of the loss of coolant but as is well documented, losing coolant can so quickly damage the engine. Therefore is it better to go over the top and just stop the engine???
    The LED will be in between the two gauges so pretty much in line of sight at all times (there is a beep in the control unit by the way but know that sometimes you keep motoring for a while trying to figure out what's that sound for lol)
    Good or bad?
    2004 Discovery 2a TD5 Auto Aspen Green AKA Robin
    2000 Discovery 2 TD5 Auto Alverston Red AKA Edward
    1997 Discovery 1 TDi Manual White - Gone but not forgotten
    1994 Discovery 1 V8 Auto - Gone once it consumed half the worlds resource of oil
    May 2021
    Mackay
    Bad, I think. Imagine it cutting out just as your halfway through overtaking that road train with another looming up rapidly from the opposite direction. Better to sacrifice your engine then yourself if the SHTF!
    Jan 2011
    Gippsland
    Quote Originally Posted by RRT View Post
    Good or bad?
    Install the coolant sensor in the reservoir tank and that will give you advance warning of coolant loss and you will have enough time to react whilst there is still coolant circulating in the engine.
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Sep 2018
    Travancore
    Hmmmm
    Quote Originally Posted by reefmagnet View Post
    Quote Originally Posted by onebob View Post
    Sure, just see it as an interesting conundrum in respect of what ifs, as to on the opposite side of the road, how long do you have till the engine seizes or a split top hose etc.?? As much as you blokes are right, do see some circumstances where it would be a good idea.
    The funny thing is, with an EWP it will keep going and empty it all out when the engine shuts down anyway - too late to take it out now lol.
    99.87 MB
    I think you'd have a bit of time to sort yourself out and pull over, it's not like if the oil runs out where the motor will be doing damage straight away.
    I've also put the sensor in the water bottle as thats the first place whcih will see the coolant level is dropping.
    Slunnie
    This is where mine is but if the head gasket is leaking the pressure can hold coolant up in the tank and the sensor will not sound.. I know this because it happened to me.
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by roverfj1200 View Post
    The D3 comes from the factory with one and there are plenty of stories of cooked motors with no low coolant alarm. Pretty much all either a split hose or broken coolant outlet.
    Apr 2016
    Country Vic.
    I dunno about the TD5, but from experience the v8 can tolerate 60 klms and/or 1 hr of no coolant(let alone low coolant).
    I wouldn't do the engine cut off system ... maybe louder alarms ... if you are so inclined.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jun 2013
    Universe A
    Quote Originally Posted by AK83 View Post
    Td5 won't like that!
    The discovery 3 tdv6 came equipped with sensor as stated, but most of them are factory disabled.
    If you want to know why, re enable it and you'll work it out.
    The one I have in my d2 works really well, in fact we got to listen to it sing for about 40 minutes a couple years ago on a dash to hospital, it was annoying (and costly) but we still got to the hospital, which was preferable to being stopped on the side of the road.
    Geelong, VIC
    IMO the only time an an engine cutout is appropriate is an unattended engine on a generator etc. Cut the engine and you lose your power steering, and brake boost (apart from some residual vacuum). To me that’s just made a low coolant issue into a potentially fatal one.
    I personally don’t bother with low coolant alarms, I just run engine watchdog head temp monitors. No false positives and they tell alert me to engine temp higher than normal - regardless of the reason.
    Steve
    1985 County - Isuzu 4bd1 with HX30W turbo, LT95, 255/85-16 KM2's
    1988 120 with rust and potential
    1999 300tdi 130 single cab - "stock as bro"
    2003 D2a Td5 - the boss's daily drive
