Results 1 to 10 of 15
Thread: BLOCK STORM WATER DRAIN.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Our old teracottta storm water pipes got blocked causing water to overflow out of 1 of the pits. I called a company and some one came a couple days later and ran a camera and high pressure water blast along the length of the drain. He found some sections had dropped and water was trapped there. and a section of tree roots. He spray painted marks on the lawn where the issues were , and the company sent me a video of the entire pipe length. The video has measurements from the pit to the fault , saves a lot of blind digging to repair.
    Back down the hill.
    Better than a colonoscopy.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    COLON YOU GET A MEDICARE REBATE THOUGH
    Back down the hill.
    I think I'd rather pay the pipe doctor, Mario.
    Apr 2007
    NW Tassie
    I got a 1/2 acre blocck witha alot of storm water pipes. Had a back flush that fooded thhe back section of my house. $6000 damage first time and a bit less thesecond time a month apart. Aafter running the camera up all my pipes and found to be all clear apart from a little bit grass root. It turned out that the council (shire) pipes were blocked annd the water wass running downthe road anddown my driveway grated sump annd backing up in my pipes. I have a BIL who is a counciler and he couldnt even get me anny sort of comp, I was only after $400 x 2, one for each claim
    blaze
    Quote Originally Posted by bblaze View Post
    blaze
    Use a different BIL.
    DL
    Apr 2007
    NW Tassie
    Quote Originally Posted by 350RRC View Post
    DL
    trouble is he is the only one that is a couciler, at least he had them digging up the road on tthe sAME DAY
    cheERS
    blaze
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    interesting the the out let pit is in the neighbours front yard near the boundary corner my more on his side.
    Sep 2012
    Westlake ,brisbane
    A few weeks ago our new neighbour two houses up who is getting a pool installed needed to pump rain water out of the shell so they pumped in in there closes storm water pipe & the water started coming out of the next door neighbour's retaining wall into our back yard . I went & stopped the workers & told them to pump it into the gutter in the street. I told the workers to let the house owner know . Few days later I went & asked the owner what he was doing about it ( they had not told him so he said) 3 weeks latter the water was still coming into out yard every time it rained , so spoke to him again to be told he had had a plumber in & the problem was in the back yard of the house between his house & ours so was not his problem & I needed to speak to our next door neighbour. 2 months on & the water still coming when it rains. I keep telling him to get a leak detector guy in to stick a camera down his drain but he thinks if he just puts the down pipe onto a water tank that will solve the problem not thinking there could be up to 6 other down pipes feeding the drain & the overflow from the tank needs to go somewhere. Think he is just trying to get out of it as cheap as possible & may be there is a problem with the pool , it's been over 6 months & pool still has not been filled & the builder took his signs away 2 months ago.
    Few years ago we has a possum go down one of our down pipes & then got stuck in the storm water pipe between the garage & street ended up having to dig up the pipe & replace it .
    Apr 2019
    Coolgardie WA
    Yeah, and don't forget to have a copy of "War and Peace" in the karzi after you have taken the 'prep' solution!...or a TV monitor..
