Results 1 to 10 of 30
Thread: Alternator Charge Voltage Not Enough for Calcium Battery
    lazbaz Guest
    I have a 2000 Reg Range Rover 4.6 Petrol P38.
    The battery spec is 112 AH; 12V and 870 CCA.
    I have fitted Hankook MF31-1000A calcium battery and requires a charging voltage of 14.7 V. The Bosch alternator charging voltage is about 14V. I need a 14.7 V alternator regulator for the Bosch ERR 5834 alternator. Any advice how I can achieve this would be thankfully received.
    Queensland
    Hi Lazbaz and welcome to AULRO.
    Your battery can be fully charged with as little as 13.8v in a reasonable time.
    But can be REGULARLY charge with up to 14.7v, and the higher the voltage the faster the charge.
    Thats all the 14.7v charging means.
    So no need for a new alternator, your will be fine.
    lazbaz Guest
    Thank you for your assurance. However this is what I read "The typical lead acid charging voltage is between 2.15 volts per cell (12.9 volts for a 6 cell battery) and 2.35 volts per cell (14.1 volts for a 6 cell battery). The ideal charging voltage for a calcium battery is 14.8V for the recombination process to properly occur"
    So I am still unsure the battery will damage quite rapidly. I was thinking of getting the alternator voltage modified to 14.7 or 14.8 V. But I have not found anyone who can do it for me.
    Jan 2017
    Geraldton WA
    Personally I would be changing my battery choice instead of boosting the voltage to suit the battery type.
    I am no auto sparky But it doesn't sound like a good idea to put that much extra voltage/ampage through an older vehicles aged wiring just to suit a different type of battery.
    4.6m Quintrex boat
    Brisbane,some of the time.
    Many with later model Tojo’s boost the voltage using a diode,it’s very easy to do,with no issues,as the LC’s alternator generally runs lower charging voltage.They have a temperature compensation alternater,not a smart alternator.
    As others have said,I would just leave it.
    Mar 2018
    Perth (near Malaga)
    Quote Originally Posted by lazbaz View Post
    There are a number of aftermarket external adjustable regulators for Bosch alternators. The car stereo guys use them to increase the output voltage.
    I'm with Tim though in that you really don't need it.
    Here's your reg : Regulator- adjustable. BOSCH sytems. – Motociclo
    You just need to either remove your reg and wire this to the existing brush pack, or replace the brush pack with a compatible set. Something like : Dave's Volvo Page - Volvo Adjustable Voltage Regulators
    The standard battery for a D3/RRS is a calcium battery and I have never seen a charging rate as high as 14.7 or 14.8 in my RRS. On start it may show 14.2-14.4v until the start charge is recouped and it then drops to 13.2-13.5v and I have not had any issues with my calcium batteries over the years.
    I think you are looking for an issue that is not there.
    lazbaz Guest
    Quote Originally Posted by 101RRS View Post
    Hi,
    What battery do you have-full name? Mine is Hankook MF31-1000A.
    How long have you had the battery for?
    I am listening to what the forum members are saying and keeping an open mind.
    lazbaz Guest
    Quote Originally Posted by trout1105 View Post
    Probably I will change battery but I have just bought this one.
    Queensland
    Hi again LazBaz and you do not need to change the battery.
    Your battery does not need to be charged at 14.7v every time you use it.
    All Calcium/Calcium ( Ca/Ca ) batteries are the same and only need a charge of 14.7v ( or higher ) once every few months.
