Results 1 to 8 of 8
Thread: Assistance needed, 2008 RR 4.2 supercharged sport- reversing camera fitting
    ShannonN Guest
    Hello All
    My Sister recently got a 2008 V8 Supercharged Rangie. This model doesn't seem to have a reversing camera setup, whether that is an option? I can't tell. Asking to see if these models have a camera feed connection at the display so I could just wire up a reverse camera to the existing display get a software U/G maybe and power away.
    Thanks in advance Shannon
    NSW SW Slopes
    Looking at the wiring schematics, both the highline and lowline entertainment systems have a video feed at the display screen. The highline's is connected to the TV tuner whereas the lowline's isn't connected to anything. I don't know the format of the signal.
    Jul 2015
    Sydney, Australia
    The Range Rover Sport screen software doesn't support a direct input reverse camera, even though the connector is there on the back of the screen. (pre-2010MY)
    You need a video interface (GVIF).
    Or there is a hack to make the screen work in Range Rover mode, but that creates other problems, and also needs CCF changes to turn on the camera input.
    2009 Range Rover Sport 3.6L TDV8
    2017 Jaguar XE R-Sport
    Supercharged
    Jags XKR & XJR 4.2L S/C
    Old Jaguar Australia - www.facebook.com/oldjaguarau
    Upgrades and retrofits for late model Land Rover and Jaguar vehicles. www.oldjaguar.com
    ShannonN Guest
    UpDate Car is 2006 model not 2008 sorry about that
    Quote Originally Posted by Cambo@oldjaguar View Post
    Hi thanks for that, found out when I visited today car is actually a 2006 model and has no rear camera fitted
    After looking at yt videos showing 2007 model with fitted camera being repaired (faulty connectors) wondering if the 2006 had the rv camera connectors under the spoiler area like the 2007 onwards /
    looking if so it should be a matter of connecting just a camera and power that way, the display should be capable of doing the rest?
    Jul 2015
    Sydney, Australia
    There was no factory reverse camera in a Range Rover Sport prior to 2010MY.
    Range Rover L322 had them.
    Range Rover Sport L320 does not, and the L320 screen software doesn't support it either.
    It's the same answer I gave you already.
    Supercharged
    St Helena,Melbourne
    1.13 MB
    Did the RRS all have the most system, after market head unit might be the go.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    ShannonN Guest
    thanks
    Look I'm unfamiliar with what designation the 2006 sport is I just picked L322 from the list I didn't know it was the L320
    I'll just fit a rearview wired mirror unit I already have to it or her, many thank all for your help
    Jul 2009
    Mid North Coast, NSW
    51.4 KB
    Arrow
    consider a new head unit or standalone reverse camera setup. if you are mounting a camera the spoiler isnt the best place if you ever tow, as you cant see your tow ball for hooking up
