6th November 2021, 05:42 PM
Is the 3.0 TDV engine same as on the D4?
Does the Disco 5 3.0 TDV suffer engine failure like the D4 (up to 2015). Apparently not, so what has changed in that engine?
6th November 2021, 07:54 PM
There were some that failed,a member on here had an engine fail,but i dont know if it was the crank.
On another note,a mechanic that worked at the Indie i used for many years,worked in the JLR warranty dept for a while.
He said there was always a steady stream of engine failures coming through.
10th November 2021, 05:10 PM
Tyres and rims
Help required please. I’m going to have to look at changing the rims and tyres on my new Disco 5 r-dynamic year 22, already 2 flats in the first weekend away travelling on dirt roads only. I was hesitant in upgrading my old D4 for this reason, although didn’t think it would be this big an issue.
Does anyone know if you can find hybrid and/or all terrain tyres for 21 inch rims ? Alternatively can I drop down to 19 inch rims and out say a coopers LTZ on - will this affect the rolling diametre and the air suspension?
Thanks all,
11th November 2021, 08:18 AM
#4
DMP
You can easily fit 20" or 19" rims from Land Rover. The 20" will give you many more tyre options. The most popular 20" option is 275/55R20 which is slightly taller but has no issues. You can also get Tuffant 18" rims which opens up a lot of possibilities.
Fuji White 2019 SE Sd6
14th November 2021, 07:52 PM
#5
14th November 2021, 09:33 PM
#6
Num thumbs, many thanks. Do you know if 275 all terrains on 20 inch rims on my22 d5 will rub ? Unfortunately it doesn’t look like the Tuffant have been tested on my 22 d5 yet. Any other rims ? besides Land Rover ones ? Thanks for your assistance. I think the offset can be a problem from the research I’ve been doing.
15th November 2021, 08:42 AM
#7
I suggest you join the Land Rover Discovery 5 Owners Group - Australia. There is a lot of information about tyres there. I am pretty sure some of the new owners are running 275/55R20 tyres. There may be some talk of Tuffants as well.
Numb Thumbs
