Results 1 to 8 of 8
Thread: Puma heater/aircon blower
    Oct 2011
    Burra NSW
    Hi,
    So my heater fan blew some white smoke out the vents and now I only have the #3 position on the fan working. I figured the fan blower was buggered as it has had some dust in it and was making a bit of noise for the past 6 months, so I replaced it with a new blower/fan assembly, however that hasn't fixed the issue, still havnt got speeds 1 and 2- aircon still works..any ideas of where else to look, cheers
    2012 130 puma
    Jan 2014
    Perth Western Australia
    My guess is...
    JGM500020 - Heater resistor
    back into that blower fan, its on the outside of the fan housing right in the corner, and can be replaced in situ
    Daz
    Oct 2011
    Burra NSW
    Quote Originally Posted by DazzaTD5 View Post
    My guess is...
    Thanks mate, I saw that when I had the blower out and was wondering what it was..cheers
    Oct 2013
    Richmond, NSW
    We had exactly the same symptoms in our 2012 90 but the diagnosis was a blown motor JGB50005 (reputable Indy in Sydney) which was $474 plus fitting 4 years ago.
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Oct 2011
    Burra NSW
    Quote Originally Posted by travelrover View Post
    I paid $525 for a genuine one, so was a bit PO that it wasn't the issue..but it got rid of the noisy fan..some plus I guess
    Jan 2008
    Melbourne, Vic., Oz
    How did you find the fitting job, ie how much stuff did you need to move?
    I found it a lot harder than you might think, given the amount of stuff to be moved out of the way... Hoping there's a better answer...
    Aug 2012
    Tewantin (NOOSA area)
    If #3 is still working then the motor is probably OK. All that is blown are the "speed" resistors. They will the
    things that let the smoke out. Find those and change out with commercially available similarly rated power (or bigger) and resistance values.
    Rick F
    Oct 2011
    Burra NSW
    Quote Originally Posted by skidrov View Post
    Very easy, and no need to remove the whole AC /fan unit. Just undo the duct from the top guard, and slide it all the way forward, 3 nuts hold the unit onto the bulkhead, and the unit can be pushed up and towards the motor to give access to the blower motor and resistors. Its a fiddly job, but not too difficult.
