Results 1 to 6 of 6
Thread: Decal TDI lower mudguard
    Mar 2010
    Queensland
    12.97 MB
    Hello All,
    Has anyone found an Australian supplier for the driver's side TDI decals? I went online and searched for decal suppliers. I found lots of United Kingdom based suppliers. The cost of freight from the UK would be excruciatingly exorbitant.
    I had to panel beat and repaint Snowy, my 1993 200 TDI Defender 110 tray-back ute's driver-side's mudguard. The TDI decal was not salvageable.
    I would just like to have a decal back on the mudguard.
    Kind regards
    Lionel
    Oct 2013
    Richmond, NSW
    Quote Originally Posted by Lionelgee View Post
    Hello All,
    Kind regards
    Lionel
    Hi Lionel
    I got one from British Motor Imports HOME in Mulgrave NSW 2 years ago
    Cheers Simon
    Travelrover
    Adventure before Dementia
    2012 Puma 90 - Black
    1999 Td5 110 Ute - White
    1996 Tdi 300 Wagon - White
    Oct 2007
    Wantabadgery, N.S.W.
    Go and see your local signwriter/vinyl sticker man/woman. They can make one from a photo and measurements. I've no idea what a one-off would cost though. Or THIS.
    Don.
    Nov 2017
    Hello All,
    Britcar UK have in the past been willing to use Royal Mail to post small/light items to Oz if requested. IIRC they quoted around $12 postage for some grommets I was chasing. Is this the decal you want (new website with no images yet so image here, Item 1)?
    P.S. I have a "Snowy" D2a, ever faithful and knows where to go. Kudos for doing your own aluminium panel beating. Respect.
    Last edited by Max Headroom 2.3m; 20th November 2021 at 02:36 AM. Reason: sin tax error
    Martin
    The secret to happiness is to truly want what you already have
    Oil leak?...Nah, sophisticated anti corrosion system!
    '04 D2a TD5 Manual "Snowy" - Daily
    '04 Def 90 TD5 "Hue" - New toy
    '03 Def 90 TD5 - Son's toy
    '16.5 D4 TDV6 - Gone
    Mar 2010
    Queensland
    12.97 MB
    Quote Originally Posted by Max Headroom 2.3m View Post
    Hello Max,
    Thank you for the tip about the possible choice of using the Royal Mail. Last week I noticed that for the same light weight electronic part from the UK the majority of UK suppliers offered 44 Pounds for postage to Australia. While a rare few offered the part for 9 Pounds freight. I went with one of the latter suppliers. I wondered at the time how there could be so much difference in freight costs. I hope the snail loaded with my part can hold its breath when it takes the big swim across the ocean.
    Working with aluminium, it helps when your efforts could not make it any worse. Also, annealing it before working on it helps a lot too. Then, annealing it again when it starts to work hardened.
    Kind regards
    Lionel
    Nov 2017
    The bubble wrap acts as floaties. Usually only works with small plasticy bits as you can't fit much on the snails back.
    How did you control the material stretching? My humble efforts usually end with the panel bulging out or wavy.
    Last edited by Max Headroom 2.3m; 20th November 2021 at 11:52 AM. Reason: Archimedes
    Martin
