Thread: Can u use a Disco-1 Front Driveshaft as a replacement on a Puma Front Driveshaft?
    Jun 2013
    Warner Area - SEQ
    Question Can u use a Disco-1 Front Driveshaft as a replacement on a Puma Front Driveshaft?
    Gents...
    Does anyone know if u can run a Disco-1 Front Driveshaft as a replacement for the PUMA front driveshaft? And if so, what are (if any) the benefits?
    Apr 2016
    I'm 99.999% sure it won't be long enough.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jun 2013
    Warner Area - SEQ
    Question
    Quote Originally Posted by AK83 View Post
    That's interesting as a mate has done it to his 130 puma... the people doing the suspension work on his car said it would help eliminate the binding up on the Yoke at the TC end @ full flex as the one on the Disco driveshaft is more "open" & won't bind up. I know the Puma Uni-joints on the front driveshaft are larger than the ones on the Disco & I also "assume" the flange bolt pattern is the same as well...
    I've just never heard this being mentioned before as being possible but it has gotten me intrigued though...
    Apr 2016
    OK then.. I may be that 0.001% wrong, but going from the Gwyn Lewis website ... and their pretty looking drive shafts:
    D1 front prop Working length :- 637mm + – 8mm
    Defer Puma Working length :- 700mm + – 8mm
    This is the info they have for their 1310 shafts.
    The info for the std shafts only state closed length ... D1 605mm and Puma 675mm
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jan 2014
    Perth Western Australia
    Quote Originally Posted by Robmacca View Post
    Gents...
    No the Defender TDCi (2007 - 2016 puma) has the transfer case set back 70mm when compared to earlier Defender models.
    Looking at the info AK83 posted it would seem the disco 1 has the same spacing (from TC to front diff) as all pre Defender TDCi (puma).
    Daz
    Apr 2016
    Quote Originally Posted by DazzaTD5 View Post
    Yeah .. as per Gwyn Lewis again, the D1 front prop fits defenders from 300 Tdi to Td5 years, and RRC's(without the BW TC). 200 tdi defenders different again at 685mm
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jun 2013
    Warner Area - SEQ
    Cool thanks for that info... I'll have to make the effort to go and actually check out exactly what they have done....
    Just one thought though... I haven't looked yet but what end is the slip joint at on the front shaft? If they are both at the TC on the D1 and Puma, then maybe this is what they swapped??
    Is this possible? I still can't see there being much difference in the yokes?? Maybe the smaller yoke allows for greater movement??
    Apr 2016
    Refit FRONT propeller shaft so sliding joint end
    of shaft is fitted to transfer gearbox.
    As per RAVE instructions.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Jun 2013
    Warner Area - SEQ
    That's interesting... so maybe the slip joints are interchangeable between D1 and Puma & that's how they did it??
    Jan 2014
    Unlikely, you may well find that the D1 shaft is right on the end of its splines.
    There is no advantage.
    If you get the odd Defender with a rumble type sound on off throttle after a +2" then using a D2 front shaft (but an actual good quality one) will solve that, but only to the end of TD5.
    The std Defender prop shaft doesnt always like the sharper angle after a lift.
    You can also get a double carden for a Defender TDCi (puma)
    Daz
