Results 1 to 10 of 17
Thread: Oil leak.
    Jun 2020
    Oil leak.
    Who'd have thought, my D2 has an oil leak. :-)
    I've had a leak since I bought it, but now - again - trying to pinpoint and fix.
    Here's a pic taken under blue light and the green is the bit of oil damming up. It doesn't appear to be from the filter or centrifugal filter housing, as I had changed them a while back and they were dry.
    Any thoughts about this?
    Nov 2014
    Nirvana near Albany W.A.
    Did you change the O ring behind the rotor filter housing? , they flatten out and leak over time
    err7098
    number 8 in the pic
    Feb 2013
    Queensland
    Have you checked the oil cooler
    Jun 2020
    Quote Originally Posted by laney View Post
    Haven't checked oil cooler, as I'll need to dismantle a lot of stuff. So trying to see if there are any low-hanging fruit here!
    Jun 2020
    Thanks for the reply.
    I take it getting the rotor filter housing off is quite the mission, judging by the diagram?
    Bolts 13, 14 and 16 the only ones needed to remove it?
    Quote Originally Posted by discorevy View Post
    err7098
    number 8 in the pic
    Nov 2014
    3x 10mm head bolts on the housing ( use 1/4" drive with extensions to access )
    2x 10mm head nuts on the bottom of the oil drain to sump
    then the whole unit will come out if you twist as you lift.
    Jun 2020
    Okay great, fantastic!
    Aug 2019
    I had an oil leak on the LHS of the engine, checked and replaced everything including sump gasket before bitting the bullet and removing the turbo to gain access to the rotor filter housing. Fairly easy job once the turbo was out of the way.
    Cheers Discofender
    Jun 2020
    These are great quality shots, thanks for sharing. Really good to get an understanding of what one would be facing.
    Did you try and remove rotor filter housing without turbo removed? Or is it simply not worth the pain. :-)
    Quote Originally Posted by Discofender View Post
    Cheers Discofender
    Aug 2019
    Hi Rymnd,
    I didn't try with the turbo in place, but having a quick look I think it could be possible by reaching up from underneath. You may need to be a bit of a contortionist.
    Cheers Discofender
