Following with interest, as I have the same issue
I've wondered if the top section of the door card could be revinyled - just the textured black bit...?
The sill trim in my MY14 D4 has started to wear where my elbow sits on the window sill. In the last couple of days the vinyl itself has teared as in the photo.
Anyone know how to tackle this? If I leave it I think its going to spread, particularly as now it has teared and exposed the sticky glued surface underneath. Replacing the trim panel would be the ultimate solution, if they are even available? Tape? Some other temporary repair?
I use the vehicle every day for work. It doesn't need to be pristine. Just a repair that is stable would be a good solution ATM.
Cheers, Chris.
2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
Mine has just gotten to this point also…
Let’s see where this thread goes - otherwise I’m off to the trimmer…
x 4
Gone 05 D3 ARB Front Kaymar Rear Winch E-Diff LRA Tank Dual Battery
Current 2015 SDV6 SE. Tow Pro Mitch Hitch Llams C/motives 70ltr w/tank 2 x comp Traxide BMS-2 x Aux 150w Solar Uniden Engel ARB drawer F/Runner rack Light bar
I had the same on my 2011 TDV6. I replaced the door card with one from a salvage yard.
Ron
2016 D4 TDV6 Corris Grey
2018 D5 TD6 SE Silicon Silver - gone
2011 D4 TDV6 2.7 Indus Silver - gone
IIDTool BT
Mines slightly sticky but still intact. You must all be heavy elbowed!
 Wizard
						Wizard
						I used these guys on my D3 which had a fairly beaten up interior. I was happy with the results, if you knew where to look you could see the repairs but anyone just getting in the car wouldn't know.
Fuji white RRS L494 AB Gone
2023 Ford Ranga
Many years ago I had a vinyl repair kit. Basically you applied a liquid to the area and then placed a "grain" pad on top to give it a similar look to the area being patched. Might be worth a look if you're not fussy about the finish.
SCA has them. Here's a link. I googled vinyl repair kit and the first pop up was a Kogan one which was about half the price but then you get inundated with spam mail for a while.
HTH.
Permatex Vinyl and Leather Repair Kit | Supercheap Auto
Martin
 ChatterBox
						Supporter
						ChatterBox
						Supporter Master
						Master
						X 5
