Results 1 to 10 of 15
Thread: Ancillary drive idler pulley
    Dec 2020
    Diamond Creek, Vic
    I want to replace the idler pulley bearing on the ancillary drive belt, but the pulley itself has a bit of wear and replacing the bearing (6302LHA) would involve drilling out the 3 rivets that hold the 2 halves of the pulley together.
    I don't want to wait for the mail from the UK and the price of around $200 for the assembly seems a bit rich when the mount casting looks fine. I have sourced a couple of part numbers for pulleys that are the right size and I wonder if anyone on here has used these. Part numbers are - Dayco 89502 or Nuline EP075. Both cost around the $50 mark and are available locally.
    Any comments?
    2005 Discovery 3 TDV6
    Thanks in advance.
    St Helena,Melbourne
    1.13 MB
    You already done the pump and belts Dave ? , I couldn't find any cross reference for the dayco pulley
    If the specs match it should be ok.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Dec 2020
    Diamond Creek, Vic
    Hi Nick, I had to find a pulley by secifying the dimensions and then double checked with Dayco that their pulley would suit. The Dayco number 89502 is correct but the Nuline EP075 was wrong. I ended up using a pulley from Bearing Wholesalers, number TT13875, which matches the spec. and is readily available.
    Taking a rest from working on the Disco today - the sweat fills up my glasses so I can't see properly.
    Happy New Year!!
    Sep 2014
    Baldivis WA
    Quote Originally Posted by Airmech953 View Post
    Happy New Year!!
    Thanks for the part numbers, on my list of replacements is a new idler pulley, starting to make a slight noise at 219000km.
    Dec 2020
    Diamond Creek, Vic
    Glad to be of use! Finding alternative ways of doing stuff and keeping the costs downis one of the strengths of sites like this.
    St Helena,Melbourne
    1.13 MB
    Comes up as a GU Patrol part, autobarn has them for $22.99.
    1974 VW Kombi bus
    Dec 2020
    Diamond Creek, Vic
    Received an email today from Dayco. They advise that the pulley 89502 is not approved by Dayco for installation on a Discovery and would not be covered by warranty. The Dayco tech support told me that there is an overhang difference of 2mm and also there are too many possibilities of installation errors (overtorquing or mechanical damage of the casting). I have installed the pulley on my machine and first indications are ok, the belt appears to run ok on the pulley. If problems surface I will advise further.
    I'll also post the list parts that Dayco recommends.
    Dec 2020
    Diamond Creek, Vic
    For those considering the use of Dayco products for the timing belts, here is the list provided a couple of days ago by their tech support people.
    I have no connection to this company, just sharing the information as supplied.
    Apr 2005 - Sep 2009, 2.7L, V6, 24V, DOHC, CRD, Turbo, Diesel, Discovery 3, 140kW, EngCode: 276DT
    Part number Application
    8PK2095 Belt Multi Acc
    132049 Automatic Belt Tensioner
    132027 Idler Pulley
    941041 Belt Cam (PTFE)
    941040 Belt Inj.P (PTFE) (from 2007 - 82 teeth)
    94989 Belt Inj.P (PTFE) (up to 2007- 85 teeth)
    KTBA288 Kit Cam
    KTBA278 Kit Cam & Inj.P (from 2007 with 941040)
    KTBA286 Kit Cam & Inj.P (up to 2007 with 94989)
    KTBA290 Kit Inj.P (from 2007)
    KTBA291 Kit Inj.P (up to 2007)
    DT260A Thermostat & Housing
    DP736 Water Pump
    Jan 2014
    Perth Western Australia
    just remove this post, what I said was all wrong...
    Daz
    Dec 2020
    Diamond Creek, Vic
    Quote Originally Posted by DazzaTD5 View Post
