Results 1 to 6 of 6
Thread: HTE Hy-Tuff Drive flanges with LR 'Dual finish' alloys
    May 2014
    Tamworth NSW
    Looking for a definitive answer- is anyone running the HTE drive flanges with dual finish alloys? For front and rear applications. Looking for info relevant to the puma vehicle.
    Is this mod a factory fit?
    OR
    Did you need to remove the centre plastic trim caps?
    Or were caps able to be modified to fit (eg trimming down the gripping prongs)?
    I'm going to undertake some significant driveline mods, but not keen on moving away from the alloy wheels just yet.
    -Mitch
    'El Burro' 2012 Defender 90.
    Wheelers Hill, Melbourne
    Not exactly answering your question, but with Range Rover Alloys, I had to have the router get to work. Silly me had the tyres fitted before trying the rims out first.
    Jan 2014
    Perth Western Australia
    If you use Ashcroft axles and drive flanges they fit behind the Defender alloy wheels as they are standard length splines.
    Daz
    Apr 2012
    Whyalla, SA
    Unless you have absolutely zero mechanical sympathy…. Look at LOF rear shafts…
    May 2014
    Tamworth NSW
    Quote Originally Posted by DazzaTD5 View Post
    So you are saying the interference is a result of spline length (over standard length) which requires a deeper/wider drive flange, and as such fitment issues?
    I'm chasing strong, so if the wheels need to go, I need to plan for that now. I'm not planning on exploding two diffs offroad at the same time again...
    You mentioned these before. They are the 1-piece design?
    I seem to recall this eliminates backlash thru the driveline / final drive - but how tough are they?
    I think the end game is 35" maybe up to 37" tyres on locked diffs, with some suspension geometry modifications longer term.
    -Mitch
    Jan 2014
    Quote Originally Posted by Toxic_Avenger View Post
    Correct, when I used to get the HTE axles and drive flanges they only made longer splines which didnt fit behind the Defender alloys enough to use the caps. Another reason was I used to have to fax my orders (to a cave somewhere) ordering was long winded when it didnt need to be.
    BUT... saying all that one of the other? indy Land Rover repairers is making them now, I dont know if they do a standard length spline now or if its a hassle to order from them.
    Bluntly... I'm not going to recommend LOF for anything, they are difficult to deal with and orders take a long time. THEY OR ANYONE ELSE is welcome to call me out on this. Quality of the axles and drive flanges? I dont know, ask for a rockwell hardness number.
    I recommend Ashcroft Transmissions for the axles / drive flanges as I've never had issues, the hardness is where it needs to be and ordering is faultless, fast, and bull**** free.
    Daz
