Thread: Air Suspension Compressor Repair kit
    Jun 2013
    Augusta WA
    Simple question I hope. I have not removed the compressor yet but I can see "Made in Japan" on it, can I assume it is a Hitachi? And where is the best place to source a kit from? Nick
    MY09 D3 TDV6 Zermatt Silver
    MY02 TD5 Bonatti Grey (Sold)
    MY00 TD5 520K (Sold)
    Mar 2016
    Photos help to diagnose which model you have. The Hitachi is easily rebuilt
    2007 Audi RS4 (B7)
    St Helena,Melbourne
    1.13 MB
    Quote Originally Posted by Pippin View Post
    Yes Hitachi, nothing else in made in Japan.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jun 2013
    Augusta WA
    Thanks repair kit ordered from X8R UK.
    Sep 2014
    Baldivis WA
    That should sort it out for you, its a good kit. Make sure to clean around the compressor and inside of the foam lined cover. I enlarged the drain hole and blew out everything with compressed air.
    Jun 2020
    Quote Originally Posted by Eric SDV6SE View Post
    I was surprised how much crud could actually get in behind the cover!
    Sep 2014
    Baldivis WA
    Quote Originally Posted by Macadamia View Post
    Yep, adds to the heat load. After putting the kit through the air side, take 30min to pull the motor rotor out of the housing and clean this out with electrical contact cleaner and compressed air. Amazing how much carbon build up and dust gets in. Your compressor motor will love you for it. Mines still the original Hitachi unit, going strong after 11 years and one full overhaul.
    May 2014
    Point Cook, VIC
    If you fit an APT compressor guard, would you leave the cover off to improve cooling?
    Jun 2020
    Quote Originally Posted by DiscoDB View Post
    I left it on. I was getting compressor faults that went away after cleaning out the complete blockage of sand in there
    Sep 2014
    Baldivis WA
    The cover partially protects the wiring and air lines from road grime. The apt bash plate from impacts. The apt plate spans the chassis rail and to the body, but provides no protection from water or dirt.
    I'd be leaving the cover in place.
