Results 1 to 10 of 22
Thread: Provent
    Jan 2013
    Mt Barker SA
    Provent
    Hello I just noticed a bit of oil under the breather hose on the rocker cover end. The turbo end seems oil free. I'm not really sure what makes a normal amount, but my engine oil never drops on weekly checks.
    I have ordered a new vent thing (The one that says "top" on it as that's never been replaced in my 9 years with the disco)
    In my googling, I came across a provent 200. Are these catch cans definitely a good idea? With my motor being over 423000km now, want to ensure old girl keeps running for long time to come! Especially since the hand controls install, can't have the motor die on me!
    How easy are they to install? As in get pipes in correct order? And where to mount one.
    What hose type needed for installation as well?
    Thankyou Provent
    Sep 2011
    I'm not so sure, I installed a catch can, good quality one at about 400,000 and then started to get pill leaks, found that the back pressure it was causing was a bit too much, ended up taking it off and with a bit of work reduced the oil leaks again. Now up to about 466,000
    Oct 2007
    Brisbane West
    How did you know it was causing backpressure? Did the oil leaks increase?
    Avoca Beach
    I wouldn't worry.
    That is a very small amount of oil and the hose is VERY old and hard. Probably a jubilee clip at the head would slow it down a bit.
    Regards PhilipA
    Oct 2020
    FNQ
    I don't know about the oil thing, but I really, really, really want to squeeze some Sikaflex onto the firewall insulation and push it back up.
    Brisbane,some of the time.
    Quote Originally Posted by ozscott View Post
    Pretty common problem with catch cans,more trouble than they are worth.
    Some vehicles normally run negative crank case pressures,if the catch can is not serviced regularly or the filter element not replaced very regularly,increase of CC pressures can cause all sorts of issues.
    Back to Epic's question,i would forget the catch can,and maybe tighten up the hose clips on the hose,the oil leak doesnt seem much of an issue.Just monitor it,the oil may have appeared over a long period of time which is probably normal.
    Make sure the TD5 is serviced regularly,properly,and it will keep on ticking along.
    Oct 2007
    Brisbane West
    I have had a good run with and only heard good things about the genuine Mann and Hummel Provent 200. Provents are used extensively in commercial diesel applications and that company is the world's largest filter company, based in Germany. I have had one in for 50,000klm now and changed the filter at 40,000klm. It has pressure relief valving for crankcase pulsing and catches a lot of crap which is what it is designed to do. Saves the intercooler, inlet etc from sludge and hard deposits. Easy to install correctly (have heard of installing the pipes the wrong way around causing oil pressurisation and people not changing the filters every 40,000k causing issues). Granted a TD5 is quite a different beast from my motor.
    Feb 2013
    Queensland
    I have a provent 200 on my td5 and have nothing but good things to say about it stops all that crap entering your turbo in my opinion they are worth having.
    Jan 2011
    Gippsland
    Provent
    Quote Originally Posted by Epic_Dragon View Post
    Hello Provent I just noticed a bit of oil under the breather hose on the rocker cover end. The turbo end seems oil free. I'm not really sure what makes a normal amount, but my engine oil never drops on weekly checks.
    Thankyou Provent
    The vent thingy marked “TOP” is a Depression Control Valve aka DCV. The PROVENT has it’s own control valve/s so you really should delete the factory DCV and replace it with a brass elbow so the PROVENT alone “manages” the crankcase ventilation that way the PROVENT will perform as designed.
    LROCV member #131
    1999 build D2 TD5 Auto, Mantec snorkel, 2" LRA spring lift, ARB on board air, Ashcroft ATB, CMM air ram CDL shifter, swag & gold pans ....
    Jan 2013
    Mt Barker SA
    Provent I've been meaning to do that for 9 years now
    Quote Originally Posted by Discosux View Post
