Results 1 to 10 of 18
Thread: Rear Diff Repair/Replacement Options
    Brissy! No flannos here!
    Hi All,
    I/We have a longish road trip throughout Western QLD planned for August, so I'm trying to get the old girl in fighting shape.
    She has a whiney rear diff with more than an annoying amount of lash that I'd like to address before setting out.
    I'm assuming that my options are replace new, or replace 2nd hand. If the gears are worn, which I suspect, is rebuild or exchange an option or cost effective?
    Has anyone done one recently and if so, willing to share indicative costs, trials, tribulations?
    Ralph
    Sep 2014
    Baldivis WA
    Haven’t had the pleasure, but a quick check on Rimmers shows a rear diff new is around 1600 bucks for OEM. If holding onto it for a bit longer, seems cheap insurance. I’m sure a tow from outback Qld back home would be more expensive.
    diy fitting should be pretty straight forward.
    Oct 2012
    You can buy a diff rebuild bearing kit cheaply from AF and DIY it. 90% common it’s one cooked output bearing so you can swap over without getting into complex lash setups on the input side for which there is no LR specs on how to setup.
    You can replace the input seal by carefully marking the lock bolt location and restoring to that exact position but try / hope to avoid any work on the input side.
    Sep 2014
    Baldivis WA
    Quote Originally Posted by PerthDisco View Post
    That makes a lot of sense, was not aware of the rebuild kits, good to know.
    Oct 2012
    Quote Originally Posted by Eric SDV6SE View Post
    Transfer Case also. It’s just a bag of bearings and a chain that are the main fail points.
    Let us know how you go as this will be a common theme from now on with ageing D3s.
    For some reason any rebuild info on diffs is unobtainium from LR so clever people have matched all the bearings into a kit.
    Outback Disco had a crack at fully rebuilding his but probably could have just done the output side to fix the rumble.
    LR3 / DISCOVERY 3 FRONT DIFF REBUILD - YouTube
    Apr 2018
    Tasmania
    His pinion bearings were totally shot as well. Any good diff builder would be able to rebuild one of those for you. While the specs aren't available, the principles remain the same...it just might not be cheap.
    Hi Again,
    So to ease my confusion, as there are lots of videos and tutorials on D3 front diffs, but much less so for rear diffs, are they interchangeable?
    I understand they will have the same rotational characteristics to keep all four feet turning the same, but are they the same beast ie, interchangeable?
    My guess is no, based on how they are mounted and the fact they take different oils.
    Ralph
    Apr 2018
    Tasmania
    Front and rear diffs are different. There is a good rebuild description over on discoweb
    Oct 2012
    Quote Originally Posted by Arch View Post
    Different configurations and look but exactly the same principle of one input and two outputs.
    Oct 2012
    In terms of a noticeable lash or clunk feeling emerging at 257k kms when changing down to lower gears at slower speeds have others also noticed this?
    What are the normal culprits I should check and is it just a process of doing an inspection on the hoist looking for slop in driveline?
    Gearbox is serviced and original so not to discount some harshness in the change that didn’t really change much after the last full service and change of the internal rubber mechatronic collars. Makes me think is elsewhere in driveline.
    How do you determine if the output drive to TC spline is the culprit?
