Results 1 to 6 of 6
Thread: Has anybody fitted a Lithium Cranking Battery to their D4.
    Queensland
    For the last 18 months or so, I have been testing a Lithium Auxiliary Battery in my Tiguan.
    The Tiguan has VERY similar SMART alternator algorithms to a D4, but unlike the D4, the Tiguan SMART alternator feature can be disabled.
    With the SMART alternator feature disabled, the Tiguan runs at between 13.9v and 14.3v and this is ideal for charging and maintaining the Lithium Battery.
    The issue I have come across with the SMART alternator feature running, is that the vehicle runs on the lithium battery ( not the alternator ) until the lithium battery is near flat, then the alternator runs long enough to put a small charge back in the lithium but then the SMART alternator drops the voltage again.
    Has any one had this sort of experience with their D4 with a lithium cranking battery?
    May 2006
    Ulverstone,TAS
    Hi mate,
    I have a lithium battery in my beast but its a 03 RR TD6. Am thinking of getting a Skoda Kodiak later this year so am
    interested in the replies.
    If your not using it for a day or three,what about putting it on to solar for a charge up.
    Would imagine that the Skoda would use same sort of alternator as the veedub.
    DG
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    Queensland
    HI DG, the D4 own electrical needs draw up to 40 amps while driving, and I want to see if any body has managed to turn off/disable the D4’s SMART alternator function?
    The problem is that when the D4’s BMS ( Battery Management System ) detects a fully charged cranking battery, the BMS runs the alternator at a much lower operating voltage.
    When a lithium battery is in the system, either as the cranking battery or as an auxiliary battery, because lithium batteries run at a constant 13.3v until they are nearly discharged ( down below 20% SoC ) the D4’s BMS incorrectly reads this 13.3v, being supplied from the lithium battery, as a fully charged cranking battery.
    In a normal lead acid battery setup, as the alternator voltage drops, so does the lead acid cranking battery.
    If the lead acid cranking battery drops to a LOADED voltage of 12.3v, approximately at 70% SoC, the alternator voltage will automatically rise to allow the cranking battery to be recharged.
    With a lithium battery in the system, either cranking or auxiliary, the voltage remains at 13.3v and as the BMS incorrectly sees the cranking battery is fully charged, the alternator voltage remains low.
    BUT, as the lithium battery voltage is higher than the alternator voltage, it is the lithium battery that is powering the D4.
    Around town is not as much a problem, particularly with lots of short runs, as the BMS normally gives an initial high voltage boost, to replace the energy used by the cranking battery to start the motor.
    This short boost also charges the lithium battery at the same time.
    The real problem will come when the D4 is driven for a long period.
    On long drives, which thanks to Covid lock-downs, I have not been able to do till just recently, in my Tiguan with the SMART alternator function turned on, after about 2 plus hours of driving, I suddenly found the lithium battery ( and cranking battery ) was down to 13.14v while driving.
    This indicated that the Tiguan was being powered by the lithium battery and the alternator was literally Free-wheeling.
    I was on a relative long drive, when I noticed the low voltage, 13.14v, so I stopped, deactivated the SMART alternator function and the voltage rose to 13.6v and remained between 13.6 and 14.3v on the return home trip.
    The SMART alternator function has remained off for a few weeks now and the two batteries has a settled voltage ( motor off ) of 13.3v at all times.
    This is the reason for the question of whether any one has a D4 with a LITHIUM cranking battery.
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    It’d be interesting to see what voltage and faults are apparent if you pull the LIN line to the alternator.
    Queensland
    Hi Brad, on the Tiguan, you simply disconnect the battery sensor plug on the cranking battery's negative terminal.
    I wonder if it is as simple as that on a D4.
    I originally disconnected the sensor plug because it deactivated the STOP/START function, but quickly found it raised the alternator voltage as well.
    WIN WIN
    NSW SW Slopes
    I just did a little test on my MY12 4.4 TDV8 L322.
    With the battery monitor disconnected from the battery's earth terminal the battery voltage with engine running hovered around 13.55/13.56V with lights off, lights on low beam and lights on high beam, but voltage rose to 13.60V once the lights were switched off. A charging system fault was displayed after a short while but not immediately.
    With the battery monitor reconnected the voltage was 14.44V with lights off, low beam or high beam.
    The vehicle had been started several times for very short periods today after last having been driven Friday morning. An aux battery is charged via a VSR which had cut-in on both test instances before any voltages were checked.
