Can't help but would be worth looking at a US based site where the V6 is more prevalent.
Hi All,
My 150k D3 V6 just had its service, following a 200km drive I returned home and noticed a ticking coming from RHS of engine. I'm almost certain it's the front timing chain guides. I've received a quote to remove the engine for 7.5k to replace front and rear guides etc.
I'm certain it just the front and would like to know if anyone else has attempted changing the front timing setup, with the engine still in the car?
Appreciate the advice, for 7.5k it's almost a write off for me. Even a second-hand motor changeover will set me back 12k..
Thanks all
Matt
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
Just Google 2004 or so Ford Explorer 4L.
I saw a second hand engine on USA Ebay for about USD1000.
The main problem as you probably know is that there are 5? timing chains with most at the back. The original Cologne camshaft acts as a jackshaft to take the timing to the back. It only has a short chain so the much longer ones at the back would also be suspect.
If one is worn/gone all should be replaced or you get a check engine light as the phasing of the cams gets out of whack.
And most places would need a timing lock set to set them up correctly.
There are some Youtubes describing what is necessary AFAIR in Spanish!
Does it sound like this:Can anyone identify this tapping noise? Thread dated 7th December 2021 have a look and a listen.
MY09 D3 TDV6 Zermatt Silver
MY02 TD5 Bonatti Grey (Sold)
MY00 TD5 520K (Sold)
The only hint that this was a petrol 4.0 is the reference to 'cologne' in the thread title. Even that is then obscure enough that anyone not too familiar with the engine options in the 3rd series Discovery platform (myself included) to assume that the engine was a diesel 2.7,by far the most common variant in the D3.
Back to the OP, have you gone back to whomever "serviced" it? This should have been picked up during any inspection by someone that knows what they are doing, regardless of engine type / variant.
7.5k to remove the engine and replace guides is an absolute joke, even at $150 an hour and say 500 in parts, it is not a job that has over 40 hours of direct labour in it by my reckoning. My suggestion is to take your business elsewhere, find a decent mechanic who is not intent on lightening your wallet.
BTW, its nice in our cave, no pesky bat viruses to deal with.
Easier and cheaper to lift the body than remove the engine.
1974 VW Kombi bus
