Results 1 to 9 of 9
Thread: Ghosting A/C and instrumentation
    Nov 2012
    Gawler
    On hot days my 2012 D4 operating system "disappears". The temperature display goes, the a/c goes off and my indicators don't work.
    Then they come back on and next I lose the whole centre display and the speedo arm doesn't work, and
    then it all works again.
    I have tightened up the earth lead and it still happens.
    no codes come up when I checked.
    Am I missing something obvious?
    Will go back to working on my 88" for a while to calm down!
    Boxpacker
    Sep 2014
    Baldivis WA
    There are several earth points. This sounds like a failing alternator diode or battery or both...
    Nov 2012
    Gawler
    Thanks Eric
    The battery is fairly new and the obvious earth was checked. I will keep looking!
    Thanks again
    Quote Originally Posted by Eric SDV6SE View Post
    Aug 2012
    Braidwood, NSW
    I'm with Eric on this. It sounds a bit like an alternator going. When mine went it did all sorts of weird rubbish. Turned things on and off, bring all the dash lights on, then lower the suspension, etc.
    Mine was over voltage, testing at 15v and climbing up to almost 17 by the time i got back around to the drivers seat and switched her off.
    If you have a multimeter handy next time it starts happening, might be worth testing the voltage at the battery.
    Otherwise, yeah, chasing down the few earth points may be worth a crack.
    Good luck mate,
    Chris
    Chris Phillips
    Offroader: 1996 Discovery 300TDI (The Green Donkey)
    Missus: 2010 Discovery 4 TDV6 (Fancy thing)
    Just 'cause: 1999 Discovery SE 3.9L V8 (Makes fun noises, sometimes...)
    Spares: 1998 Discovery 300TDI (Only vehicle actually in the garage..........)
    Run around:
    2001 Nissan Pulsar ST 1.8L (Soul crusher)
    Feb 2009
    Quote Originally Posted by Boxpacker View Post
    Thanks Eric
    Thanks again
    What's fairly new, exactly? They can quit after as little as 2 years...
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    St Helena,Melbourne
    4.28 MB
    Sounds like a cluster failure to me, more common on a D3 than D4 but still something to look at.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Nov 2012
    Gawler
    Quote Originally Posted by libertyts View Post
    I'm with Eric on this. It sounds a bit like an alternator going. When mine went it did all sorts of weird rubbish. Turned things on and off, bring all the dash lights on, then lower the suspension, etc.<br>
    <br>
    Mine was over voltage, testing at 15v and climbing up to almost 17 by the time i got back around to the drivers seat and switched her off.<br>
    <br>
    If you have a multimeter handy next time it starts happening, might be worth testing the voltage at the battery.<br>
    <br>
    Otherwise, yeah, chasing down the few earth points may be worth a crack.<br>
    <br>
    Good luck mate,<br>
    <br>
    Chris
    <br>
    <br>Thanks Chris and Eric,<br>Checked the alternator and it seems to be okay insofar of multimeter reading, the battery, however, read a bit sick on voltage. I changed the Varta battery in the vehicle and in new one on loan and I will see how it goes. It only happens after mid 30's temeratures so lets find out!!
    My next step will be the alternator
    <br>Regards<br>Tony
    Oct 2021
    Western Australia
    Sounds similar to the issues ScottA & I are having with ours:
    Discovery 4 electrics turn off while driving
    I'll be picking up mine from the mechanic this afternoon following a major service, they haven't been able to identify the cause of the issue but have been through earth points & checked for loose connections as part of the service. Service will reset systems as well.
    Will have to see if this is a fix, if not alternator, battery & BMS are next on the list of potential causes.
    2014 D4 XXV
    Nov 2012
    Gawler
    Quote Originally Posted by Steve86 View Post
    Thanks for that, new battery in mine yesterday and no issues for the first time in 3 days so here's hoping!!!
    Tony
