Results 1 to 2 of 2
Thread: Interior trim replacement
    Apr 2014
    Mount Eliza
    Hi all, looking to spruce up the interior of the Disco and wanting to replace the trim surrounding the gear selector as well as the bit under the main screen. Any idea where to source these parts? Are they easy to remove/replace?
    Jan 2015
    Hi, for the trim under the screen the part number depends on the colour. Meteor for example is LR021339. You can just lift it up carefully with a trim tool.
    Trim around the gear selector I'm sure someone will be along shortly to answer.
    David
    Everything is easy when someone else is doing it
    MY14 SDV6 SE Corris Grey
    Compomotive 18s : D697s : Traxide DBS : LLAMS : ARB compressor : IC-455
    Rhino Platform : GOE compressor, Tx & front bash plates, deluxe sliders
