Results 1 to 10 of 15
Thread: LR072856 High Mounted 3rd Brake Light - what sealant/silicone adhesive to use?
    Feb 2011
    Hobart, Tasmania, Australia
    Question LR072856 High Mounted 3rd Brake Light - what sealant/silicone adhesive to use?
    What sealant or silicone adhesive is used when replacing the LR072856 High Mounted 3rd Brake Light? I assume something like Sikaflex 227 would be detrimental to the next time the light housing needs to be replaced.
    Jun 2013
    Augusta WA
    Quote Originally Posted by twr7cx View Post
    Sikaflex was a complete failure when I saw my new HM Light spiralling through the air in my rearview mirror and it was professionally fitted. The windscreen shop covered the cost of a new replacement but refused to fit it. I did it myself using clear gutter silicone after a test on the broken one and it has held firm for two years so far. Nick
    MY09 D3 TDV6 Zermatt Silver
    MY02 TD5 Bonatti Grey (Sold)
    MY00 TD5 520K (Sold)
    Mar 2016
    I used sikaflex and copious amounts of it, plus prepared the surfaces really well including alcohol wipe down etc. mine has never leaked or come off. I think in the above case it wasn’t the adhesive’s fault but the person who applied it ineffectively. If you follow the instructions and look how much the factory uses, it’s a lot.
    2007 Audi RS4 (B7)
    Jun 2013
    Augusta WA
    Quote Originally Posted by DiscoJeffster View Post
    The person that applied it did use an activator before fitting with Sikaflex but the bond was very week. If you are fitting one yourself it's wise to do a test on the old one first just to be sure.
    Feb 2022
    QLD
    Forget 227. Sikaflex 296 is the professional marine glass bond. If that doesn't stick, there's something wrong with your process. It's rated as suitable by the international maritime organisation... That's an approval for where people might die if it fails... (I build wooden boats as my other passion). 3M also do some outstanding adhesives with a bit of flex/temp 'give' in them, but not sure which one would be right for glass/acrylic. The one that is used on wood is affectionately known as 'the devil's toothpaste' - once it's cured, most boatbuilders accept that the bond is unbreakable if you want the substrate to survive...literally - you cut it out and start again.
    Feb 2009
    I'm interested to know how you go/went getting the old one out? Heat it up first or just smash and scrape away?
    Now 2016 D4 HSE 'Leo' and Steve the Triumph Speed Twin
    Then 2010 D4 3.0 HSE 'James'
    Then 2010 RRS TDV8 'Roger' w traxide DBS, UHF, Cooper Zeons, Superchips remap
    Then 2010 D4 TDV6 'Jumbo' w traxide DBS
    First love 2002 D2 TD5 'Disco Stu'
    Oct 2012
    Quote Originally Posted by Stuart02 View Post
    Complete demolition and then knife out the old adhesive with a scalpel
    Mar 2016
    Yeah that’s how I did it
    2007 Audi RS4 (B7)
    Feb 2009
    I'm not sure I'm brave enough!
    Sep 2014
    Baldivis WA
    It will be therapeutic
