Thread: What’s this noise?
    Jan 2012
    What’s this noise?
    This could be a regular segment on the forum.
    I’m getting a strange noise and vibration from front suspension under braking only.
    So, under mild braking:
    Steering wheel feels like a left/right pulling (I initially thought this was warped rotors)
    This was then added with a soft thumping noise (like the tyre noise when you drive over the road cat eyes). (Not the clunk from LCA, and repetitive under braking).
    Any ideas?
    Sep 2014
    Baldivis WA
    What age vehicle? Most likely wheel bearings if still original. If under braking check caliper slides and possibly sticking pistons. Check brake pads also
    Jan 2012
    Quote Originally Posted by Eric SDV6SE View Post
    What age vehicle? also
    Still a baby…MY16 / 105,000 kms
    Mar 2016
    Quote Originally Posted by SimmAus View Post
    Have you checked the lower control arm bushes. That causes the symptoms you describe
    2007 Audi RS4 (B7)
    Jan 2012
    Quote Originally Posted by DiscoJeffster View Post
    Thanks…I have initially discounted the LCA bushes..as these usually cause a clunk noise over speed bumps / hard braking.(well, at least in my past experience)
    I don’t get that…it’s only on braking…and more of a thump noise than clunk (very scientific description..I know)..
    Sep 2014
    Baldivis WA
    I found on mine that the upper control arm bushes go too, although this was at 200000km.clunking under braking tells me something is loose or not moving as it should. Need to check all ball joints for play. Suggest a suspension place looks at it unless your going DIY.
    Jan 2012
    Just to close out my own question:
    Had the LCA replaced today (107k kms) so thought that was a good first step.
    Problem fixed
    Diagnosed: one ball joint shagged, LCA bushes on their way out.
    Rotors and wheel bearings checked…all good.
    She now drives like new…happy days…
