Thread: Topping up the transmission
    Jul 2015
    Bowen
    I know that when refilling the transmission we need an accomplice to go through he gears while we fill, to overflow. As there is nearly always a red drop to be seen underneath I thought I should check for a top up. Got the wife to go through the selections but when I undid the filler plug out gushed fluid. Am I doing something wrong? Thought I would check it as there is a harsh rattly sound when taking off until she changes up to second. Any ideas what is going on? Had this noise for a while bit it seems to be getting harsher. Otherwise the trans seems fine, nice smooth changes.
    On a brighter note the barn door is now sweet and the passenger front window fixed. Another annoyance is the low fuel light coming on after about 300km, when I know the tank is more than half full. On a full tank the needle reisters just over ½ . I've always been able to drive 130 km before the needle drops on a full tank. I guess there must be a float attached to the pump in the tank. Likely it is leaking? If so, is it fixable or do I need a whole new expensive unit? Just put a couple of new tyres on her so I'd like to get a bit more kms before she goes.
    Thanks people!
    May 2015
    Williamstown, Victoria
    The float could be buggered. I think you'd notice a fuel leak. I wonder what could bend the float arm!?
    Build date 11th Oct 2003
    LROCV #1410
    Feb 2011
    Hobart, Tasmania, Australia
    Could over full be the cause of the issues you are experiencing? Try allowing it to drain out all the excess.
    I assume you have the engine running when going through the gears.
    Jul 2015
    Bowen
    Quote Originally Posted by Bohica View Post
    No fuel leak apparent. Might have to have a look at the pump.
    Jul 2015
    Bowen
    Quote Originally Posted by twr7cx View Post
    Overfull seems unlikely as I "thought" it was spot o when I serviced it before dragging the trailer sailer Horsham to Bowen in 2019. Since then I might have done 1000km light duties. I would have expected it to have leaked a bit since then. After all, it is a Land Rover
    Yes, engine running when going through the gears (I forgot to mention that before)
    I think I might try draining the XS as you suggest......engine running, going through the gears.
    Jul 2014
    PERTH, WA
    Auto Trans fluid TEMPERATURE
    Quote Originally Posted by Tinggu View Post
    Hi Tinggu,
    Do you know that the auto trans fluid is meant to be at a temperature of 37 degree Celsius when you check level or top up?
    You will see this stamped on the underside of the auto trans sump.
    37 degree C is only about the same as the temperature of your hand.
    From my own experiences with this, I suspect that the ATF has a high thermal expansion co-efficient, so that the volume in the system increases greatly as it heats up.
    Avoca Beach
    I think you are overthinking this.
    When I do it alone I go through the gears then under and finally top up with engine running.
    The instructions AFAIR say that the fluid should flow out of the plug a bit with engine running.
    The 37C probably refers to someone changing the fluid in the Arctic, because remember nearly all of these were sold somewhere in Europe.
    I don't think the expansion is any different to any other oil.
    I think the excess coming out if with engine stopped is from the cooler . that is why it is done with the engine running so the cooler is filled.
    Regards PhilipA
