Originally Posted by
Mudnut
My 2005 TD5 Defender has been getting progressively hard to start. Would crank, and I could watch the battery voltage drop until it would either start, or need to be charged with my battery charger. Looked into possible reasons, and was looking at injector seals, air in fuel. Oil in wiring harness..... Most of the standard reasons.
I then crawled underneath and had a look at the starter motor. It didn't look like it was hanging right, so reached up and gave it a shove. The whole thing moved about 10 mm. All three bolts were loose, and it was not making good contact to the block. Tightened the bottom two, and the Defender has fired right up since. I might have to through bolt the bottom two, as they didn't seem to tighten much. I think either the bolts or the threaded section of the block are stripped. Should be a cheap and easy fix though.
So if TD5 difficult to start, ensure starter motor is solid against the block. Takes 5 seconds.
Ken
