Results 1 to 4 of 4
Thread: SLS Parts
    May 2009
    Tatura, Vic
    SLS Parts
    Putting in new bags on the rear of my D2. The old bags are fitted with a push in air line.
    The new ones come with a screw in line.
    The olive for the screw in fitting is a split olive and it was very tight on the air line.
    Trying to push it on it split in two.
    Can I get a standard type olive from a air fittings shop and use one of them?
    Anyone had this same problem?
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Jul 2014
    west of Transylvania
    I think that if you find the same size and shape olive it should be OK unless you can find such voss connector in a shop down under Land Rover Discovery II 1998-'04 VOSS Suspension Air Line Hose Connector Fitting | eBay
    May 2015
    Williamstown, Victoria
    Pirtek, not porter, bloody auto correct! has them. 4mm. Enzed also Will have them. I got mine from Pirtek
    Build date 11th Oct 2003
    LROCV #1410
    May 2009
    Tatura, Vic
    Do places like Pirtec/Enzed have the exact same split type olive or is it just a standard type?
    Dave.
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
