Results 1 to 10 of 18
Thread: 2016 Discovery SDV6
    Mar 2007
    Tarneit VIC
    2016 Discovery SDV6
    Looking to buy 2016 SDV6 with 175000km. I was just wondering what to look for when buying D4 with this mileage?
    Gus
    Oct 2012
    A low price and full service history
    St Helena,Melbourne
    4.28 MB
    First up would be timing belt and fuel pump are almost due @180k, transmission service which may not have been done at all.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Mar 2007
    Tarneit VIC
    Quote Originally Posted by PerthDisco View Post
    How much is considered low price for D4 HSE for that age? Thanks
    Mar 2007
    Tarneit VIC
    Thanks. I read a long time ago about the steel pan of auto box. Do I need to check if it has bee replaced? Thanks
    Mar 2016
    Quote Originally Posted by fourteen8 View Post
    You can’t get a steel pan for an 8 speed which is what’s in the 2016.
    2007 Audi RS4 (B7)
    Feb 2022
    QLD
    It's an interesting one. I'd say the key, if negotiating on price, is that cambelt service at around 180,000k. I actually bought a 2015 (2016my) 8 speed at 195,000, in part because that service had been done. If not, its due, and could easily run you $3k plus or minus, depending on what is found/what else you elect to do at that point (which is sensible because you've paid for all the labour to get the body off...)
    I'd also want to pore over the complete service history: has it had transmission oil changes already done? If not, check the gearchanges carefully. The 8 speed is supposedly more reliable and simpler than the older 6 speed, but the 'sealed for life' rubbish is not helpful. Ideally fluid changes at about 60k, and certainly every 100k. Mine also had several complete brake discs and rotor changes, front and rear, and upper and lower control arm changes, diff and transfer box flushes, etc.
    If it's been regularly serviced by one independent, not run ragged off-road, and looks cared for, go for it at a sensible price. Mine had one careful owner, never taken off road, or towed, and had been used primarily as a long distance motorway commuter on the sunshine coast, by a non-mechanically minded owner who didn't mess with it, but just did what British Off Road recommended they do at each service. It's pretty much spotless, in stock condition, and runs /handles like a new car - I'm aiming for 500k out of it. The money saved compared to brand new is substantial, and pays for some serious TLC. At its next service I'm going to preventatively change the alternator out, because that's getting to be high milage for the original, which will be consigned to the touring spares box...
    Dec 2018
    Boho
    I find that an interesting one regarding the preventative changing of the alternator. I've asked my well regarded Melbourne Indi service center about doing that myself and was advised against it. They said they'd seen failures of the alternator at almost every conceivable km/age of the vehicle so if mine wasn't showing any warning signs at each service just leave it alone. My 2011 D4 has now clocked up 195k km. Food for thought.
    Mar 2007
    Tarneit VIC
    Is SDV6 in discovery and range rover the same engine?
    Looking arlund for other option with the same price bracket. Wife and daughter prefer range rover but me and son prefer disco 2016 Discovery SDV6
    Jun 2020
    yes and TDV6 is also the same engine but a slightly lower tune
