Results 1 to 8 of 8
Thread: Stub axle wear on hub
    Jul 2011
    Yallingup
    Metal filings in he grease around front hub bearings is never a good thing…. When I stripped the stub axle I noticed evidence of metal on metal wear between the stub axle plate and the rear lip of the hub ie where the rear seal goes in. Pictured. Can anyone confirm if this wear would be due to bearing fail allowing the hub to shift too far back on the stub? The bearings looked ok but there was oil all over the brake disk suggesting worn rear seal. The stub has lots of wear marks and evidence of metal on metal wear on the plate behind the rear seal. I’m thinking of getting a new stub and bearings etc but re using the current hub.
    Apr 2016
    I don't know much about hubs and stubs(other than having renewed my bearings and stubs on my D1(same type) ... but looking at the image of the wear mark on the stub, looks more like a manufacturing defect in the form of a high spot that interfered with the hub.
    If the worn bearing were to cause interference between hub and stub, you'd think that the metal to metal contact patch would be a circular one all round(or partly all way around .. or whatever) ... not just the one small spot as in your image.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Either warn bearings or loose bearings. Did you notice a soft brake pedal at all? If the bearings are loose, the hub will wobble, causing the brake disc to wobble and push pads back/pistons back into caliper.
    Replace bearings can cups as they will be contaminated
    The stub axle may also need to be replaced if there is groove warn on the surface where the hub seal sits.
    Andrew
    1998 Landrover Defender 300Tdi 130 HCPU Expedition
    1972 Peugeot 504 Sedan - Daily Driver
    Apr 2019
    Looks like the stub has been already been speedi sleeved?
    Apr 2016
    Quote Originally Posted by W&KO View Post
    Don't they all look like that after some miles on 'em?
    I replaced all four on my D1 just after getting it(preventative, and one noisy bearing) and all four had the same bearing marking on them to a degree. Some more than others but all 'faced' with the inner bearing race in the same manner.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Apr 2019
    Quote Originally Posted by AK83 View Post
    Was more looking at where the hub seal runs……could be wrong, hard to see.
    350RRC's Avatar
    350RRC is offline ForumSage Silver Subscriber
    It looks like that to me too, and the weird wear is due to the sleeve not being seated home flush.
    It wouldn't be easy getting a sleeve that big perfectly flush outside of using a machine shop.
    Inner bearing inner cone has been spinning on the stub as well for some reason........... lack of lube in the hub, incorrect adjustment or dud bearing.
    DL
    Jul 2011
    Yallingup
    Thanks all for you input. I got a new stub, seal and brass bush from west coast rover and fitted today. To note the top pin on the swivel was worn causing the swivel housing to rock slightly this could have caused wear to the bearings etc…. Have rebuilt the swivel new pins and bearings. All seems good now.
