Results 1 to 4 of 4
Thread: discovery 2 replacement key fob
    Mar 2021
    melb
    hi just wondering if anyone has used one of these. I need to replace my originals urgently.
    Complete To Suit Land Rover 2 Button Key Remote Discovery 2 Range Rove – Remote Pro
    They say they are 433mhZ mine is disco 2 year 2000. would this be compatible or how do i find out mhz of original
    Thanks all
    john B
    Apr 2016
    Country Vic.
    Quote Originally Posted by johnbor View Post
    Thanks all
    john B
    Hey John.. why do you need to replace your originals?
    Specifically! ... is it just the case that's worn to high heaven, or is there a problem with the operation?
    If the battery is dead, simple change.
    If the case is just worn to high heaven(normal for regular use vehicles of the age .. you can buy just the case for it, so the shell then becomes good as new, and you use the internals of your current one .. in the new shell.
    The key blank pulls out of the body of the old one, and insert that into the new shell too.
    Saves a ton of $s, and no need to program it again too.
    If your originals are suffering from circuit board failings .. then of course new keys make sense.
    Just an FYI.
    Arthur.
    '03 D2 Td5 Auto
    '03 D2a Td5 Auto
    Mar 2021
    melb
    Replacement fob
    Yeah need to replace. Outer cases are fine, been down the polmex path 10 years ago, but both now have loose microswitches or lost micro switches. Need some new internals. Genuine are quite expensive
    Jun 2017
    Apologies if you already know all this.
    Have you considered removing and replacing the microswitches? They are easy to source online (ebay, key fob supply companies) and re-soldering them to the old circuit board is pretty straight forward.
    It seems a shame to discard the key fob circuit boards if they can be saved.
    Also, you don't then have the added hassle of registering the new keyfob(s) even though that is pretty straight forward in of its self with a Nanocom.
    '99 Discovery 2 TD5
    '76 Range Rover (Land Rover 50th Anniversary Great Australian Trek vehicle)
    'MY13 Range Rover Sport SDV6 Autobiography
