Results 1 to 8 of 8
Thread: Puma Defender Clutch Slave Cylinder
    Jan 2010
    Huntley, NSW
    Hello All,
    I've just had the clutch slave cylinder fail in the 2011 (2.4) Puma. Does anyone have any advice on a good replacement brand and place to source in Australia? I don't really have the time to wait for one to be sent from the UK.
    Rohan.
    alien's Avatar
    alien is offline A Keeper of the TGO Silver Subscriber
    Bacchus Marsh Vic.
    When ours failed I had Les Richmond’s(Thomastown Vic) change ours and also did the clutch at the same time as it’s a gearbox out job. They told me the at the replacement slave and associated piping had been upgraded later in the production run so fitted the newer system/parts.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    Jan 2010
    Huntley, NSW
    Quote Originally Posted by alien View Post
    I thought it must be a "gearbox out" job as I couldn't find the slave cylinder externally. I'm hoping my diagnosis is right but I'm also pretty sure it is.
    Thanks for your reply Alien. You have confirmed my worst fear unfortunately.
    Rohan.
    Jan 2014
    Perth Western Australia
    If you dont want to wait for parts then find a repairer that stocks the needed bits. Which also gives you an idea that they have done plenty of them.
    I buy the below listed bits generally 20 at a time.
    I replace as a minimum:
    Clutch kit (whatever brand you prefer) (shameless plug: ClutchFix)
    LR068979 Cylinder - Clutch Slave (FTE)
    LR068981 Adapter (genuine)
    LR068982 Valve - Control (genuine)
    LR032880 Also being a 2.4 you can replace the Crankshaft position sensor rubbish heat shield with the later 2.2 shield
    LR052893 Also fit the 2 shift assembly alignment collars.
    Also mod the diff lock assembly so it doesnt plop out of diff lock on every bump
    etc etc... so much more to do right
    Daz
    Jan 2010
    Huntley, NSW
    Quote Originally Posted by DazzaTD5 View Post
    Where are you located Daz?
    Jan 2014
    Quote Originally Posted by HUE166 View Post
    I'm way over here in W.A ... but hey don't let that stop you I'm doing a Defender TDCi clutch and adaptor shaft this week from QLD
    To be fair though... surely there are dam good indy Land Rover repairers somewhere over that way.
    Daz
    Apr 2007
    MUSWELLBROOK
    Hello All,
    Rohan.
    4WD Industries should have them in stock.
    Mark
    Brisbane,some of the time.
    A bit North of Huntley,MR auto did ours,bit of a different job than the D1 of my Brothers.
    The Puma design is just wonderfull,i suppose its a Ford dumb set up
