Results 1 to 10 of 28
Thread: Any hot tips while ive got my headliner out?
    shayne86 Guest
    So i finally pulled the headliner out. Sick to death of looking at the sagging liner. Was a lot easier than i though. Hardest part was getting it out the back door.
    Anyways, while i have the headliner out does anyone have any hot tips on jobs that can/should be done while i have the roof exposed? Run wiring for extra lighting, sound deadening etc etc.
    What has everyone else done that required the roof lining to come off?
    Cheers everyone
    Oct 2020
    FNQ
    Put a later model key fob receiver in - if its possible to sync the later model with the BCU?
    much easier to get fobs for the plastic headlight models.
    shayne86 Guest
    Quote Originally Posted by Discosux View Post
    Not a bad idea. Unfortunately i just had two brand new keys made up for the old girl
    Back down the hill.
    Might be a good time to remove and reseal the alpine windows and check for rust.
    Seals for the roof rails if you have them fitted.
    May 2015
    Williamstown, Victoria
    Sound and heat insulation.
    Will you need wiring in the future?
    Build date 11th Oct 2003
    LROCV #1410
    shayne86 Guest
    Quote Originally Posted by Bohica View Post
    Im not sure. Ide love to have this thing lit up like nobody's business once the funds allow
    shayne86 Guest
    Quote Originally Posted by LOVEMYRANGIE View Post
    Yeah they are still in place although it would be nice to **** them off since i have a full length roof rack now. I believe they require quite a large rubber grommet to seal?
    Now would be a good time to do it, you'd need to hunt for a good blanking plug to seal it off though otherwise a high density closed cell foam sheet (ie 8mm wetsuit rubber) and cut new ones to suit.
    Jan 2013
    WA
    Hi Shayne86 MKII posted this if you want to get rid of the rails
    MkII
    Member
    There are a few different tutorials online about removing the roof rails. You need to drop the sides of the head lining to access the bolts. I was given the run around trying to find grommets that fit into the holes left by the rails (35mm) but eventually found these ones from Rare Spares:
    They are about $8 each. Its hard to get them into the holes given the large external diameter but it lets you fill it up with silicone. I haven't had any leaks yet, even with some really heavy recent storms.
    Cheers tt
    D2 2004 TD5 Classic
