Thread: Bolt on battery terminal
    Feb 2022
    ACT
    I have tried searching, but there doesnt seem to be a specific detail on any post.
    I am putting in a positive feed from a spare spot on my positive battery terminal, but cannot seem to find an M8 bolt that is short enough. The smallest i have found is 16mm long, but even that seems too long.
    What does everyone use, and where do you get it?
    Brisbane,some of the time.
    Cut off with grinder easy as.
    Feb 2022
    ACT
    Unfortunately, while i do have a grinder, i have no easy way of holding the bolt while i do it.
    Jun 2018
    Redesdale
    Quote Originally Posted by hisnhers View Post
    Vice grips? Thin piece of ply with a hole drilled in it with the bolt fed from underneath held down on a bench?
    My RRS is a 2.7 so may have a different arrangement to you. I just used the bolt that is already there that secures one of the main +ive cables.
    Standard arrangement
    Now with my additional power cable attached
    St Helena,Melbourne
    4.28 MB
    I used a longer bolt with an extra nut on my negative terminal clamp which would also work on the positive terminal clamp.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Feb 2022
    ACT
    Quote Originally Posted by 101RRS View Post
    I was hoping to use the one that is empty there - I bought a M8 nut and washer so will try that, it's a bit crazy around here at the moment, so still havent got to it yet
