Results 1 to 9 of 9
Thread: Engine ECU disappeared from GAP TOOL
    Oct 2011
    Fremantle WA
    Went to connect my GAP Tool in Instrument mode for a trip away but could only get voltage to display, but none of my usual engine readouts (turbo temps x 2), and temps for radiator engine oil and transmission. Engine ECU does not appear in the directories either.
    Oh mother, what have I done?
    Mar 2016
    I don’t think it’s picked up what car it is. Close the app and end it, then reconnect. Maybe also disconnect and reconnect the gap tool.
    I’ve had it do it once.
    2007 Audi RS4 (B7)
    Oct 2011
    Fremantle WA
    Quote Originally Posted by DiscoJeffster View Post
    Thanks, I've done that. It also shows the correct VIN.
    But I'll try it yet again.
    BradC is offline Super Moderator
    No one of consequence
    Supporter
    Mar 2018
    Perth (near Malaga)
    Might not be able to pick up the high speed CAN. Double and triple check the pins are all straight and clean and try reseating it. I’ve had the opposite where it couldn’t see the medium speed CAN before.
    Dec 2017
    wandin nth vic
    Been a while since I've used my gap tool. But I think you need to click 'show all ecu ' or something to that effect.
    Jan 2018
    Lilydale, Victoria
    Culd the information in the bright red block have anything to do with it? First page of the manual.
    2016 Discovery 4 SDV6 HSE, Mitch hitch, Traxide dual battery, LLAMS, iCheck TPMS, APT side steps and compressor cover.
    2016 AOR Matrix Pop Top camper trailer, now sold.
    2023 Sunseeker Desert Storm (aka Titanium Hardcore ATX)
    Jan 2018
    Lilydale, Victoria
    Quote Originally Posted by Odysseyman View Post
    Oct 2011
    Fremantle WA
    I have been known to leave it in overnight eg during recent 8 week trip to Sydney and back, but
    1 - I religiously ensure it is turned fully off before leaving the car
    2 - on this occasion it had been sitting unconnected in the car for a few weeks prior to the "non connect"
    I'm also aware that others keep theirs permanently in their cars subject to 1 above with no problems.
    Time to contact Patrick in Canada I think - I have checked the under bonnet fuses, and those in the top glovebox, and going to get one of my contortionist grandies to check the bottom in car fusebox.
    Oct 2011
    Fremantle WA
    Well, Patrick from GAP Tool very quickly sorted me out
    "This is because the tool was not connected with engine running or ignition ON after being updated.
    To avoid this, always connect the tool with either engine running or ignition ON.
    To fix it,
    -Start the car
    -Connect the tool
    -Menu--IIDTool Config--Find ECUs"
    Only part he didn't add was after doing the above, disconnect, then reconnect and everything is back as it should be.
    Always get prompt and usually easily understood responses from him - knows his product well!
