Exacto what just happened to me.
ShaneShed has videos on replacement.
Step 1 - with engine off pop apart the vacuum line quick connector in front of booster and you might hear the air suck in as some verification the NRV is working. You may notice oil oozes out as well (mine did not).
Step 2 - with engine running you should be able to feel vacuum suction at the connection. Put your thumb over it.
Step 3 - with a long flat blade screw driver prize the vacuum line out of the booster. It’s a friction fit into the rubber seal so work carefully in a few directions and it will pop out. The screw driver can get behind it so you don’t snap it off.
Step 4 - using something long and flexible dip for signs of oil in the booster. My oil extraction vac pump worked here and I also was able to suck out oil. Not a heap but an obvious amount. The rubber grommet comes out making a bigger hole to see into with a torch and you will easily see oil contamination.
Mine worked again intermittently after doing this - it is no fix. Your booster is cooked.
Step 5 - buy updated RRS booster and watch Shane Shed videos.
I took my vacuum lines completely off and by blowing into them you can verify the NRV works. I washed mine in soapy water and very little, if any, oil came out. I did not replace the line or touch the vac pump.
Hardest part of whole job is getting that damned safety clip off the brake pedal. Extreme torture.
New TRW RRS booster is amazing. Less than $300 delivered via AF.
