Hmmm. I’d suspect it but also:
What’s the voltage on the engine side when it’s running and the voltage on the aux side?
Leave it with the dual setup disconnected etc. and see if the primary still goes flat. If it does then you know it’s not to do with the aux?
My TD5 alternator had an issue but it was revealed with lots of smoke from under the bonnet rather than a civilised flat battery!
				1974 Military Lightweight Landy --- Some dementia at 50 years old
2000 Disco series 2 now sadly moved on!
No5 Trailer joined the fold... Awaiting graduation to road licensed!
2021 Mazda BT50 or is that DMax?
