Thread: Adblue use towing van
    Jan 2012
    Geelong Vic
    Currently travelling with friend who has 2019 sdv6 towing 3tonne van. Travelling at average speed of 90-100K. Use over 2800k is 23 litres of adblue, equates to 122km per litre. Dealer says it’s normal. Price here in Kalgoorlie is $60 for 10 l container. All this plus difficulty of filling, it’s very slow, is enough to steer one towards a Toyota. Anyone had this experience / comments.
    Peter
    2015.5 RR Vogue TDV6
    2016 XE Jag 20D Prestige
    2003 MB SL500
    May 2003
    On The Road
    Sorry, but ti's why I went 16.5 L494..
    I talked today with a SDV6 D5 owner towing a van( what are the odds two Loire Blue LR's next to one another in Katherine??) who is very happy with his choice,, I think I'd work on the fill issue--
    Trucks use the exact same stuff... most big truck stops pump it...
    Jan 2020
    McGowanastan
    As pedro says, truck stops pump it and they all pump it slowly so I cant see why it couldn't be pumped directly into the car , but, I havent seen the location of where it gets filled on a D5.
    At the pump it's been around the $2.45 to 2.80 depending on where I have fuelled up. That's worth the experiment when hes paying $6 a ltr.
    It seems it works on a ratio of fuel burnt so the figures should be comparable to normal use, although in saying that we have 1 truck in our yard that seems to drink far more than the rest , but apparently its within the manufacturer recommended limits.
    Bulletman
    Dec 2009
    Perth WA
    Quote Originally Posted by peter g View Post
    Currently travelling with friend who has 2019 sdv6 towing 3tonne van. Travelling at average speed of 90-100K. Use over 2800k is 23 litres of AdBlue, equates to 122km per litre. Dealer says it’s normal. Price here in Kalgoorlie is $60 for 10 l container. All this plus difficulty of filling, it’s very slow, is enough to steer one towards a Toyota. Anyone had this experience / comments.
    Peter
    Hi Peter,
    I use about 300Km per liter when towing my Zone van at around the same speed. Does drink more when going up & down hills and less on the straight.
    I refill a 15ltr container at my local Shell or Puma garage. I use a small magnetic coupling which goes around the end of the pump nozzle and this enable me to fill the container.
    price varies between $1.50 to $1.99 per ltr.
    I then decant into 3 x 2ltr containers which came with my D5 and pour this straight into the fitting under the bonnet.
    Hope this helps.
    Cheers Tom
    Tom, I wonder what Peter’s mate did - changed to a Toymota or not?
    You have replied to a 7-8 month old thread.
    I suspect that the AdBlue filler on the D5 was designed by the work experience kid. Like the tow bar on a Discovery 3...
    If you try to fill it on the flat at anything beyond a dribble it burps and blows back continually. First time I did it it took over an hour and a half to get 15 litres in via a funnel. I would not even try to use the pump at a servo.
    To fill mine I have learnt to park the car with the front higher than the rear - the higher the better - and I use a portable electric pump - the ones that look like the old syphon pumps but use a battery - so I do not have to hold a 10 litre drum up in the air. It still takes a while...
    I tow just under two tonnes - I have no interest in towing three tonnes anywhere - and my AdBlue consumption is way higher than not towing, but it is nothing like one litre per one or two hundred kilometres.
    Numb Thumbs
    Fuji White 2019 SE Sd6
    Mar 2022
    Nomad/ travelling Australia
    Adblue Funnel
    [QUOTE=DiscoTom;3184543]Hi Peter,
    Hope this helps.
    not sure if you know they exist.
    I go to truck stops and fill a 10L plastic jerry. I then fill using a proper adblue funnel that has a breather hose built in. Much faster and no mess.
    Last edited by craighammonds; 1st May 2023 at 03:55 PM. Reason: Spelling issues etc
