Results 1 to 10 of 24
Thread: What LT tyres should I fit to my 2013 D4?
    North Avoca
    G'day All,
    I've just bought a 2013 Discovery 4 with 134,000 km on the clock. Most impressed with it!
    It's fitted with 19" Wranglers but I while I have nothing against Wranglers, I would prefer 18" all terrain LT tyres.
    On my previous two Defenders I've run BFG and Coopers tyres. But the D4 has air suspension with which I have no experience and I'm wondering if this has any impact on what tyres work best for 4wd touring.
    No longer into rock crawling or so called "technical" 4WD'ing.
    Any advice would be greatly appreciated.
    Mellow Yellow
    Mellow Yellow
    No matter what the problem - there's a solution. You've just got to find it.
    2013 Discovery 4 TDV6 3.0
    2015 Defender 90 - The TARDIS (Gone)
    2003 Defender 110 - The Yellow Peril (Gone but remembered fondly)
    2001 Discovery II TD5 (Gone)
    1986 County V8 (Gone)
    Apr 2012
    Whyalla, SA
    Hello and welcome,
    Plenty of tyre threads on here to read. What LT tyres should I fit to my 2013 D4?
    You’ll need some 18s that can fit over the larger brakes of your model - Tuffant is your go there.
    Then look at a 265/60-18 Falken WildPeak. Fantastic tyre.
    NSW SW Slopes
    I recently fitted GG AT3 255/60R19 on D4 rims to my L322. They're LI 113, not LT but seem to have a tougher case than the 255/55R19 version which is only LI 110. They have quite an open pattern for an AT that is performing well in sloppy mud. Tempe Tyres in Sydney import them and currently have stock.
    St Helena,Melbourne
    4.28 MB
    I'd stick with the 19's if you don't really need the extra sidewall height.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Oct 2016
    Perth, AU
    I’ve been wondering when this size would turn up - excellent, will take a look next tyre change!
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    NSW SW Slopes
    Tempe Tyres listed them as on-order shortly after I asked if they might add this D5/L405/L494 size to the list of other GG AT3 that they import. They provide the same sidewall height as 255/60R18. I swapped from 275/55R20 to get the same sidewall height and the higher load rating but 31" dia not 32". I bought 6.
    Jul 2013
    Hello and welcome,
    I'll second the wildpeaks, been an excellent tyre so me so far
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    NSW Far South Coast
    I'm on my 3rd or 4th set of Bridgestone D697. Can't fault them! They have been perfect. I would\will buy another set unless someone can convince me there are better\newer tyres out there. I was almost convinced about the Falkens, but met a guy near Gibb River Rd that had a puncture. We were both travelling similar roads. Probably just luck of the draw, but!
    Oct 2012
    Quote Originally Posted by ytt105 View Post
    Same
    Mar 2012
    melbourne
    I run BFG 265/65/18 on my D4, can't fault them, done heaps of different terrains from the Gibb and heaps of top end to SA beaches to Vic high county, performed well in all conditions and wearing well.
    I think suitable pressures and driving to the conditions is more important than what factory they came from
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
