Thread: D2 Pretensioner short to power
    Jun 2020
    G'day all.
    So, "out of nowhere" (could be a Landy slogan) my SRS light came on and upon reading the codes with Nanocom, the code 024 "RH Pretensioner measures short to power (permanent)" came up as the issue at hand. Suffice to say, resets and ensuring the plugs are fine doesn't move the needle.
    I did a lot of troubleshooting, each time disconnecting battery leads for 10 minutes and then doing testing. A few notes on tests:
    1) Disconnecting pretensioner plug under seat changes the fault code to "RH pretensioner open circuit (permanent)". Plug it in, and back to "short to power".
    2) I measured the RH pretensioner plugged in, car off and battery disconnected, and it comes up with 2.6 ohm. I'm led to believe that means the pretensioner is fine. (When unplugged, it's a dead short.)
    3) Taken off centre console and inspected wires of SRS DCU, unplugged it, etc. Can't find anything dodgy.
    4) Resetting with Nanocom takes light away for few seconds, and then it returns.
    I'm out of ideas! (Probably another slogan coined by us Landy operators. )
    Help as always appreciated!
    Cheers.
    Ray
    Back down the hill.
    Sierrafery, our resident guru, will along presently. If he doesn't know something about Land Rover electrics, it's not worth knowing.
    Avoca Beach
    They are supposed to be replaced every 10 years. Mine are only 10 years overdue.
    I wonder how much one would cost?
    Regards PhilipA
    Nov 2017
    Regards PhilipA
    It appears that in the UK, not replacing them at 10 years would be an MOT fail.
    They are about $340 each plus shipping.....ouch! I wonder how many have been replaced in Australia?
    Last edited by Max Headroom 2.3m; 15th June 2022 at 11:43 PM. Reason: Forgot the link
    Martin
    The secret to happiness is to truly want what you already have
    Oil leak?...Nah, sophisticated anti corrosion system!
    '04 D2a TD5 Manual "Snowy" - Daily
    '04 Def 90 TD5 "Hue" - New toy
    '03 Def 90 TD5 - Son's toy
    '16.5 D4 TDV6 - Gone
    Apr 2010
    South Melbourne
    Golly - after 12 years of ownership didn’t even know I had these!
    Jun 2020
    Definitely a head-scratcher. Hopefully Sierrafery has some insights!
    Jul 2014
    west of Transylvania
    Hi, nr 1 proves that the DCU and the circuit are OK, you get short circuit with the pretensioner unplugged cos it has a shorting spring clip within the connector which is supposed to close the circuit when the connector is unplugged and be pushed to open when the plugs are connected so it's possible that the problem is there and the shorting clip is stuck closed so insist in that area
