Results 1 to 10 of 23
Thread: D4 specific questions
    Jan 2020
    McGowanastan
    Gday All,
    So I have a couple questions which relate to D4 , I did try to search this but read lots of threads with no real definitive answer .
    So what is the difference between SDV6 and TDV6.? My original thought was it was the early D3 engine but it seems the TDV6 is twin turbo in the D4.
    Also in relation to the deisel engine model , is the D4 suffering the HPFP issues in the later years say 2014 onwards..
    The failing of the manifolds, was this fixed in later models,? From what I read I cant see anything to suggest so, but is there a km range they are failing in ?
    Is the manifolds issue happening on both SDV6 and TDV6 engines.
    Thanks and cheers Bulletman
    Mar 2012
    melbourne
    Quote Originally Posted by Bulletman View Post
    Gday All,
    Engines are exactly the same, just the tune is different, both twin turbo, no idea on HPFP issues, manifolds have continual "upgrades " apparently but the later ones will more than likely still fail , after all its still the same basic design but maybe the changed ribbing on the later ones may make a difference. Whether it is enough of the difference to remove the failure all together I doubt that very much
    Discovery 1 4.6, true trac front and rear, superior engineering arms,old tourer now bush toy
    Discovery 4 3.0 HSE MY13 ECB Bull bar, winch, spot lights, aux fuel tank, Kaymar rear bar, duel wheel carriers, 18 tuff ant wheels 265/65/18 BFG KO2's for play
    Jan 2020
    McGowanastan
    Quote Originally Posted by discomatt69 View Post
    Thanks, interesting with the manifolds as its basically the same engine as the D3 and no failure that I can find, so obviously the extra HP and associated higher pressures from 2 turbos is enough to cause the failure so would be an interesting ratio of TDV6 to SDV6 failures.
    Cheers Bulletman
    Dec 2009
    Baldivis WA
    Gday All,
    So what is the difference between SDV6 and TDV6.? 3.0ltr engines are mechanical identical. My original thought was it was the early D3 engine but it seems the TDV6 is twin turbo in the D4.
    Also in relation to the deisel engine model , is the D4 suffering the HPFP issues in the later years say 2014 onwards. Not that I’m aware of.
    The failing of the manifolds, was this fixed in later models? The manifolds had various revisions, my MY14 TDV6 with 160,000Km is still currently on the factory manifolds. From what I read I cant see anything to suggest so, but is there a km range they are failing in ? No idea.
    Is the manifolds issue happening on both SDV6 and TDV6 engines.Yes can happen to both engines.
    See my answers in red
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    Feb 2022
    QLD
    Yup, the lower state of tune is one of the reasons I 'seized' a late model 8 speed TDV6 - it's about as safe as you can get with respect to potential reliability, I hope - no guarantees, but it's the best combo of least stressed engine and bullet proof transmission, if you drive/service with care...
    Mar 2012
    melbourne
    Quote Originally Posted by Jpdv View Post
    Ah yes but the SD tunes is sooooo nice, vroom vroom
    After 6 years of ownership I still get a grin moving 3 ton as fast as it does when you blow out the cob webs
    Sep 2014
    Baldivis WA
    Exactly, and with a ecu flash tune and evc the grin just gets wider.... really want the manta 3" mandrel bent 409 stainless exhaust, but 3k is a bit steep
    Jan 2020
    Shelbourne, Victoria
    I had the left manifold replaced in December and the right replaced in January on a 2012 SDV6 at just under 200k kms.
    Both failed with cracking.
    2012 Discovery 4 SDV6 SE with ARB bar and Traxide DBS
    Mar 2017
    I'm replacing both sides inlet manifold this month after passenger side cracked - SDV6 160k km.
    When the D4 was released the SDV6 was the 3.0 engine and the TDV6 was the 2.7.
    After the 2.7 TDV6 was dropped it was replaced by a lower tuned 3.0 called the TDV6.
    As mentioned the 3.0 SDV6 and the 3.0 TDV6 are the same engine but with the TDV6 in a lower state of tune. Why LR did this never seemed logical to me - just go with the one state of tune.
