Results 1 to 10 of 14
Thread: Fault and Limp Mode ONLY when driving about 12km's or around 15mins -- Please Help --
    Feb 2022
    Sunshine Coast
    Hi,
    I have a 2011 Land Rover Discovery 4 SDV6 SE Auto 4x4 MY11
    Im trying to figure out why im getting limp mode and car lowers to access height only when i drive for around 12km's or 15mins. It does not happen all week when i stop start to work and back (about 7kms) however when i get on the motorway and drive further it happens every time.
    I thought it might have been the battery as ive only had the vehicle 4 months and cannot see how long the previous battery has been installed so replaced it, however it still happening.
    Could it be a module that is heating up over a certain time/distance that triggers limp mode?
    I have it booked in for a service and testing however mid-July is earliest.
    Thanks for your help, much appreciated
    Dec 2009
    Baldivis WA
    First step is to read the error code(s). Until you have that information it’s all just guesswork.
    2014, MY14 Discovery TDV6, Fuji White (2018-Now)
    2003, Discovery 2a, Td5 Manual, Zambezi Silver (2012-2018)
    2007, Adventure Offroad Campers, Grand Tourer (2015-Now)
    NSW SW Slopes
    Lowering is because there is a brake system fault.
    Check the wiring harness that runs along the chassis behind the left front wheel to see if it has broken its retaining clip and has been rubbed by the inside edge of the tyre causing broken or shorted wires.
    Sep 2014
    Baldivis WA
    Without error codes it is just guessing. An educated guess from me is get your wheel alignment checked, if the steering angle is off, this faults the abs, esc and most other systems.
    Feb 2022
    Sunshine Coast
    Quote Originally Posted by kelvo View Post
    Thanks Kelvo. I figured that might be the only way to know.
    I do have a cheap micky mouse ODB2 reader however think its probably not accurate?
    These below is from the scanner:
    Car Scanner ELM OBD2
    DTC report
    Selected brand: Land Rover
    ============1==============
    P2264(00)
    Raw code: 226400
    ECU: Engine control unit
    Status: Test failed, Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear
    OBDII: Fuel/water separator sensor - circuit malfunction
    ============2==============
    U2101(00)
    Raw code: E10100
    ECU: Transmission control unit[Archive (inactive)]
    Status: Test failed since last DTC clear
    OBDII: CAN data bus - ECM incorrectly programmed
    ============3==============
    P2264(00)
    Raw code: 226400
    ============4==============
    U2101(00)
    Raw code: E10100
    ============5==============
    C1B00(64)
    Raw code: 5B0064
    ECU: ABS control unit
    Status: Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
    ============6==============
    U3000(55)
    Raw code: F00055
    ECU: Transfer case[Archive (inactive)]
    OBDII: Control module
    ============7==============
    U0416(68)
    Raw code: C41668
    ECU: Body[Archive (inactive)]
    OBDII: Invalid data received - vehicle dynamics control module
    ============8==============
    U0128(00)
    Raw code: C12800
    ECU: Dashboard[Archive (inactive)]
    OBDII: Data bus, parking brake control module - no communication
    Feb 2022
    Sunshine Coast
    Hi Graeme,
    Thanks for this info, ill investivage this avenue. Strange the faults trigger while driving on the motorway without touching the brake but then again its a Land Rover so sounds like anythign is possible.
    Feb 2022
    Sunshine Coast
    Quote Originally Posted by Eric SDV6SE View Post
    Hi Eric,
    I wonder if you're onto something here as while driving straight the steering wheel is off center, the car does pull slightly to the left and i have noticed at times what feels like a wheel not balanced.
    The below image is the car driving straight.
    The brakes are also squeeking now so probably need new pads and discs.
    Mar 2016
    Quote Originally Posted by skimitchell View Post
    Hi Eric,
    Dude! That screws with all the systems. You must have the wheel pointing forward when driving forward or steering angle sensor will be flagging errors from the TCCM etc. That is likely your issue
    2007 Audi RS4 (B7)
    Feb 2022
    Sunshine Coast
    Quote Originally Posted by DiscoJeffster View Post
    Ok, so is this something wheel alignment guys can rectify of does this require adjusting the steering wheel? Im hoping this is starting to sounds like an easy cheap fix.... Fingers crossed !!!
    NSW SW Slopes
    To add to the above post, the steering angle sensor is attached to the ABS ecu hence a brake system fault, possibly real but with the steering wheel at that angle the fault is likely a plausibility fault as it doesn't compute to be turning left yet all wheels are travelling at much the same speed.
