Results 1 to 10 of 12
Thread: iPhone connection to D4
    Mar 2007
    Tarneit VIC
    Hi
    I just bought D4 2014 few weeks ago and how can I get or setup to access last call and phonebook on the iPhone from the D4 audio unit. Thanks
    Oct 2014
    Boronia (Victoria)
    Quote Originally Posted by fourteen8 View Post
    Hi
    Cambo on this forum is the guru on such matters.
    2017 L494 RRS SDV8 HSE. Sound system upgrade, 2018 facelift rear spoiler, tail lights and grille upgrades. Cambo Trans. Re-Map.
    2013 Discovery 4 HSE 3 Ltr V6 - sold
    Feb 2022
    QLD
    It should 'just work', I think. I have a 2015, and both my wife's Iphone and my android connect seamlessly via bluetooth. Once connected, the 'phone' button under the top screen offers up the usual last 10 received/dialled/missed etc, and a phone book option. Certainly did nothing complex or special to make it happen....
    Apr 2012
    Whyalla, SA
    Check in your phone the settings are on to share info:
    This is mine
    Oct 2016
    Perth, AU
    Probably improved in later years, however mine had a limit on phone book size. Needed to share only a portion - using the groups like on tombie’s pic.
    CarPlay renders it useless obsolete now.
    2010 TDV6 3.0L Discovery 4 SE remapped to RRS output, Alaska White, GME XRS-330c, IIDTool BT, Dual Battery, Apple CarPlay, OEM Retrofitted: Cornering lights, Door card lights, Power + Heated Seats, Logic 7 audio
    Mar 2007
    South Arm, Tasmania
    I have a 2011 D4 and iPhone. Last call and address book etc all work without problem in mine. Don't remember ever having to do anything special to get these features to work, other than pairing the phone with the car. Think I'm on my third iPhone since I've had this car, and never a problem with any of them. Old pic below - I've got a newer cradle in the same location now to fit the iPhone X.
    Cheers .........
    BMKAL
    josh.huber Guest
    When I first paired my phone there was an option to tick which said upload contacts etc.. or something like that.
    Mar 2007
    Tarneit VIC
    Thanks. I will try tomorrow all the suggestions and will update here.
    Quote Originally Posted by BMKal View Post
    Sorry to hijack this thread but BMKal, can you please share how you have mounted your Nav screen?
    Land Rover - The leader in chasis rust protection with leading edge oil application system.
    2000 Discovery TD5 - ACE. 2" Lift and Bloody big lights
    2016 Discovery D4 SDV6 HSE ARB Bar, lights and winch. Wow
    Mar 2007
    South Arm, Tasmania
    Quote Originally Posted by eckolsim View Post
    "KUDA" mount for the Discovery 3/4. Not sure if they are still available - AMAZON is showing out of stock and not sure if/when will be back in stock.
    IMGA0973.jpg IMGA0974.jpg IMGA0984.jpg IMGA0995.jpg IMGA0996.jpg IMGA0979.jpg
    TPMS screen is also mounted to the KUDA mount, via a flexible gooseneck screwed into the side of the KUDA body. I have been surprised with how well this thing supports the weight. It has been installed since 2016 and nothing has ever failed / moved, and I have driven some pretty rough roads since that was installed. Still also using the same phone mount, though I have had to install a new cradle on it to accommodate the larger iPhone X. Have been thinking of buying a console mount and shifting the phone down to that, as it is not easy to see the screen where it is behind the steering wheel.
    Cheers .........
    BMKAL
