Results 1 to 10 of 12
Thread: Alternator loose bracket?
    Jul 2013
    I've had an annoying buzz from my engine that developed not long ago - the sort of buzz that something loose makes. Anyway when it first came up I had a poke around and seen a couple of the timing belt cover bolts where loose so assumed that was it. Wasn't to worried and figured I'd sort it out at the next service. Anyway today I've been changing out the AC compressor so while all the belts and fan are off I figured it's the perfect time to have a decent look. Well I was quite surprised to see the alternator moving around as it was loose. The whole bracket it bolts to including the tensioner is moving around. Looks like one of the top bolts is missing so it's either come loose and falled out or the bolt has sheared. Anyway I'll find out some more tomorrow as I'll pull it all apart and figure out what's gone wrong. Just wanted to share what I've found here to see if anyone else has had something similar happen to them.
    I'll post a quick video up a little later so you all can see
    Shane
    2005 D3 TDV6 loaded to the brim with 4 kids!
    http://www.aulro.com/afvb/members-rides/220914-too-many-defender-write-ups-here-time-d3.html
    Jul 2013
    Shane
    St Helena,Melbourne
    4.28 MB
    Not enough ugga dugga's after the belt change ?
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Jul 2013
    Probably not - Ive never removed the alternator
    Shane
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by shanegtr View Post
    You haven't replaced the oil pump ?
    1974 VW Kombi bus
    Jul 2013
    Yeah, but I cant remember pulling out the alternator. In all fairness it must have been 6, nearly 7 years ago since I've changed it
    Shane
    Jan 2013
    No Fixed Address
    It looks like the bracket is broken at the top. Watch it move in the video.
    07 TDV6 2.7 D3 SE
    Sep 2014
    Baldivis WA
    Yup, the bracker holding the alternator on is broken
    Jul 2013
    Bracket not broken, just the bolts holding it to the block. One bolt was missing, two others snapped off in the block
    Shane
    Oct 2012
    You can barely fit a little spanner in that neck of the woods let alone anything big enough to snap bolts so it’s mysterious.
